Configuring Lookups
The following table lists the lookups that are part of this integration.
Lookup Name
Integration Name
Purpose
OFSCSOM_ActionCode
Oracle Utilities OFSC CCS Activity Complete
Translates the OFSC status to corresponding SOM action Code
SOMOFSC_ActivityType
Oracle Utilities CCS OFSC Appointment Get
Oracle Utilities CCS OFSC Activity Process
Oracle Utilities OFSC CCS Activity Create
Translates SOM Activity type to OFSC Activity type
SOMOFSC_ConfigProps
Oracle Utilities CCS OFSC Activity Get Status
Used for configurable properties
SOMOFSC_InterimStatus
Translates activity status in OFSC to status in SOM/C2M/CCS
SOMOFSC_TimeZone
Translates SOM time zone to OFSC time zone
SOMOFSC_MeterConfigurationType
Oracle Utilities OFSC CCS ServicePoint Query
Translates SOM meter configuration type to OFSC meter configuration type
SOMOFSC_MeterLocation
Translates SOM Meter Location to OFSC Meter Location and vice versa
OFSCSOM_MeterStatus
Translates SOM Meter Status to OFSC Meter Status and vice versa
SOMOFSC_CountryCode
Translates SOM Country Code to OFSC Country Code and vice versa
SOMOFSC_Email_ID
Configures the email IDs of respective user
SOMOFSC_LifeSupport
Translates the life support codes from SOM to OFSC
OFSCSOM_Appt_Timeslots
Translates OFSC time slots to SOM time slots and vice versa
OFSCSOM_StatusReason
Translates OFSC cancel reason to SOM.StatusReason field
OFSCSOM_ReadSequence
Oracle Utilities OFSC CCS Device Verification
Transforms the SOM Read sequence to OFSC Read sequence and vice versa.
OFSCSOM_Decimals
Maps the SOM Decimals to OFSC Decimals and vice versa.
OFSCSOM_Dials
Maps the SOM Dials to OFSC Dials and vice versa
SOMOFSC_Key
Maps the SOM Key to OFSC Key and vice versa
SOMOFSC_DeviceLocation
Maps the SOM Device Location to OFSC Device Location and vice versa
SOMOFSC_MeasurementCondition
Maps the SOM Measurement Condition to OFSC Measurement Condition and vice versa
SOMOFSC_AttachmentBO
Maps the OFSC Mime types to SOM attachment BO.
SOMOFSC_Sync_RegisterSQIData
Oracle Utilities CCS OFSC Admin Sync
Maps the Serial number to OFSC SQI property label.
SOMOFSC_Sync_RegisterTOUData
Maps the Serial number to OFSC TOU property label.
SOMOFSC_Sync_RegisterUOMData
Maps the Serial number to OFSC UOM property label.
SOMOFSC_Sync_ActivityData
Maps the Serial number to OFSC activity property label
SOMOFSC_Sync_DeviceConfiguration
Data
Maps the Serial number to OFSC configuration property label.
SOMOFSC_Sync_DeviceManufacturer
Data
Maps the Serial number to OFSC manufacturer property label.
SOMOFSC_Sync_DeviceModelData
Maps the Serial number to OFSC model property label
SOMOFSC_Sync_DeviceTypesData
Maps the Serial number to OFSC device types property label
SOMOFSC_Sync_DeviceHeadEnd
SystemData
Maps the Serial number to OFSC head end system property label
SOMOFSC_ActivityTypeConfigProps
Maps the OFSC activity type properties values
SOMOFSC_LanguageCode
Maps the SOM language code to OFSC language code
SystemData
Maps Sequence number to OFSC Property Label
Editing Lookups
To edit a lookup:
1. Login to Oracle Integration for Cloud.
2. Navigate to Projects > OU CCS OFSC > Lookups.
3. Select the lookup to edit.
4. Make the necessary changes.
5. Click Save and Close.
