Migrating from OIC Test Environment to Production
Make sure all Oracle Integration Cloud artifacts are imported successfully.
To import the customizations added in the test environment to production:
1. Export the ccs_ofsc_fieldwork_custom_25.4 project from the test environment and import it into the production environment.
Note: For information about upgrading an older version of integration to 25.4, please refer to the
Oracle Utilities Customer Cloud Service Integration to Oracle Field Service Upgrade Guide 25.4 included in this release. The documentation is available on the
Oracle Energy and Water Integrations page on
Oracle Help Center.
2. Configure all your connections in the Connections section of the Accelerator project.
3. Activate the base integrations and customized integrations, and configure the respective end point URL into the Oracle Utilities Customer Cloud Service Message Sender and OFS plugin as applicable.
4. Deactivate the base integrations for which a cloned, customized integration copies were created.
