Properties
Properties are customs fields used to enable the Utility Integration specific UIs created, and to map the Oracle Field Service UIs. Each property is classified into types (such as field, integer, enumeration and string) based on the requirements. They should be addressed using this property.
To import the property file that is a part of the accelerator package:
1. Navigate to the Configuration page.
2. In the
Resources, Activities, Inventories section, click
Properties, and then click
Import.
3. Browse to select the file to be imported. Click
Import.
4. Verify the successful import of the file. Successfully imported should be 365 and Imported with warnings to be 0 and Not imported to be 0. Click Close.
