Auto Pay Setup
The error messages in the Auto Pay Setup inbound web service are as follows:
Table 6-3
Message Category Message Number Message Text Comments
3 253 Name field missing.
3 40004 An account cannot have multiple auto-pay options effective at the same time.
3 52401 End Date "<value>" cannot be before Start Date "<value>".
11001 107 Value (<value>) for field {ApayMaxWdrwlAmt} has too large a precision (15) or scale (2).
11001 1850 Input request field Third Party Auto Pay Setup Action has an invalid value. Invalid Lookup value <value>. Valid values are for field THRD_PTY_APAY_SET_ACT_FLG (e.g. C1AD C1CN C1UP ...). (11001, 1850) is a common message number that has parameters for field name and the reason that the field is invalid
11001 1850 Input request field Account has an invalid value. Referenced FK ACCT Account ID <value> by table Account does not exist. (11001, 1850) is a common message number that has parameters for field name and the reason that the field is invalid
11001 1850 Input request field Start Date has an invalid value. Invalid date value <value>, expected in format YYYY-MM-DD and should fall between 1753-01-01 and 9999-12-31 date range. (11001, 1850) is a common message number that has parameters for field name and the reason that the field is invalid
11001 1850 Input request field End Date has an invalid value. Invalid date value 01-31-2018, expected in format YYYY-MM-DD and should fall between 1753-01-01 and 9999-12-31 date range. (11001, 1850) is a common message number that has parameters for field name and the reason that the field is invalid
11001 1850 Input request field Maximum Withdrawal Amount has an invalid value. Invalid numeric value <value>. (11001, 1850) is a common message number that has parameters for field name and the reason that the field is invalid
11001 1850 Input request field Payment Type has an invalid value. Invalid Extended Lookup value <value>. Valid values are for BO C1-PaymentTypeLookup (e.g. 12 CREDITCARD SAVINGS ...). (11001, 1850) is a common message number that has parameters for field name and the reason that the field is invalid
11001 1850 Input request field Credit Card Type has an invalid value. Invalid Lookup value <value>. Valid values are for field CARD_TYPE_FLG (e.g. C1VS C1AM C1MC ...). (11001, 1850) is a common message number that has parameters for field name and the reason that the field is invalid
11102 10423 Action is required (11102, 10423) is a common message number where the specific field name is a parameter
11102 10423 Account ID is required (11102, 10423) is a common message number where the specific field name is a parameter
11125 10001 Third Party Payment Processing Integration master configuration not found. No action needed from third-party payment processors. Issue is caused by internal config.
11125 10003 Auto Pay Setup processing script not found. No action needed from third-party payment processors. Issue is caused by internal config.
11125 11002 You are signing up and canceling auto-pay on the current date. Please call a representative for assistance.
11125 11003 Unable to determine auto pay source. Please check Credit Card Type.
11125 11004 Unable to determine auto pay service task type. No action needed from third-party payment processors. Issue is caused by internal config.
11125 11005 Expiration Date is invalid. Month should be entered in MM format and year should be in YYYY format.
11125 11006 Unable to determine auto pay source. Please check Routing Number.
11125 11014 Start Date is required when Action is Add or Update.
11125 11015 End Date is required when Action is Cancel.
11125 11016 Payment Type is required when Action is Add or Update. (11125, 11016) is a common message number where the specific field name is a parameter
11125 11016 Account Number is required when Action is Add or Update. (11125, 11016) is a common message number where the specific field name is a parameter
11125 11016 Name is required when Action is Add or Update (11125, 11016) is a common message number where the specific field name is a parameter
11125 11018 Auto Pay ID is required when Action is Update or Cancel.
11125 11023 Input request field Auto Pay ID has an invalid value. Auto Pay ID (<value>) does not exist.
11125 11024 Start Date must be on or after the current date when Action is Add or Update.
11125 11025 End Date must be on or after the current date when Action is Add or Cancel.
11125 11026 End Date must be after the current date when Action is Update.
