One-Time Payment Notification
The error messages in the One-Time Payment Notification inbound web service are as follows:
Table 6-1
| Message Category | Message Number | Message Text | Comments |
| 11001 | 106 | Length of value <value> (in bytes) too long for Field Account ID. Maximum length: <value> Found <value>. | (11001, 106) is a common message number where the specific field name is a parameter |
| 11001 | 106 | Length of value <value> (in bytes) too long for Field Service Task ID. Maximum length: <value> Found <value>. | (11001, 106) is a common message number where the specific field name is a parameter |
| 11001 | 106 | Length of value <value> (in bytes) too long for Field Payment Event ID. Maximum length: <value> Found <value>. | (11001, 106) is a common message number where the specific field name is a parameter |
| 11001 | 1850 | Input request field Payment Type has an invalid value. Invalid Extended Lookup value <value>. Valid values are for BO C1-PaymentTypeLookup (e.g. 12 CREDITCARD SAVINGS ...). | (11001, 1850) is a common message number that has parameters for field name and the reason that the field is invalid |
| 11001 | 1850 | Input request field Payment Amount has an invalid value. Invalid numeric value <value>. | (11001, 1850) is a common message number that has parameters for field name and the reason that the field is invalid |
| 11101 | 401 | Service Task ID not found. | |
| 11102 | 10423 | Payment Date/Time is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11102 | 10423 | Payment Type is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11102 | 10423 | Payment Amount is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11102 | 10423 | Routing Number is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11102 | 10423 | External Account Number is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11102 | 10423 | Credit Card Type is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11102 | 10423 | Credit Card Number is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11102 | 10423 | Expiration Month is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11102 | 10423 | Expiration Year is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11102 | 10423 | Account Number is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11102 | 10423 | Service Task ID is required. | (11102, 10423) is a common message number where the specific field name is a parameter |
| 11125 | 10001 | Third Party Payment Processing Integration master configuration not found.ent Process service task processing script not found. | No action needed from third-party payment processors. Issue is caused by internal config. |
| 11125 | 11013 | This Tender Type <value> should not generate auto pay. | |
| 11125 | 11006 | Unable to determine auto pay source. Please check Routing Number. | |
| 11125 | 11019 | The system cannot cancel a service task already processed for cancellation. | |
| 11125 | 11020 | The system cannot cancel discarded requests or requests in error. | |
| 11125 | 11028 | One Time Payment Cancel processing script not found. | No action needed from third-party payment processors. Issue is caused by internal config. |
| 11125 | 11030 | Service Task (<value>) does not exist. | |
| 11125 | 11031 | Payment Event (<value>) does not exist | |
| 11125 | 11033 | The payment linked to this service task was cancelled through service task %1. | |
| 11125 | 11034 | This service task is a cancellation request for service task %1. | |
| 11125 | 11035 | The system cannot cancel a request for cancellation. | |
| 11125 | 11100 | Third Party One Time Payment Add/Update service task processing script not found. | No action needed from third-party payment processors. Issue is caused by internal config. |
| 11125 | 11102 | Unable to determine One Time Pay service task type. | No action needed from third-party payment processors. Issue is caused by internal config. |
| 11125 | 11103 | Payment Type is not configured as one of the Accepted Payment Types. | |
| 11125 | 11110 | Payment Amount cannot be zero. | |
| 11125 | 11113 | Payment Amount is invalid. | Incorrect formatExample: non-numeric or incorrect precision/scale |
| 11125 | 11114 | Only pending one-time payment can be processed. | |
| 11125 | 11201 | Payment Event (%1) Payment Tender (%2) - Invalid Payment Date/Time %3, expected in format yyyy-MM-ddTHH:mm:ssXXX. |
