Supported Functionality
This section describes the functionality supported by this integration point.
Change the Appointment Time for an Order
If a customer changes the appointment time for an existing order, the CSR can use Oracle Utilities Customer Care and Billing to cancel the old appointment, request a new available appointment slot, and select an appropriate appointment time slot in consultation with the customer.
The following diagram depicts processing when an appointment is changed:
Assumptions and Constraints for Appointments Processing
• You can search for available appointment slots for only one field activity at a time.
• Errors are displayed in the UI.
