Scenario 1: CC&B + MWM + WAM v1.9.1.x
In this scenario, the integration product coordinates processing between three Oracle Utilities application products based on the configuration settings described. All three application products and the integration product must be configured to enable this business scenario. This section of the document describes the configuration required for one of the application products.
Configure Oracle Utilities Mobile Workforce Management for Scenario 1
At a high-level, you must complete the following steps in Oracle Utilities Mobile Workforce Management to configure the integration:
1. Configure the admin tables to support the integration:
• Activity Types
• Batch Processes
• Service Areas
• Appointment Booking Group
2. Configure the extendable lookup tables to support the integration:
• Device Manufacturer
• Disconnect Location
• Meter Configuration Type
• Meter Location
• Payment Cancellation Reason
• Service Instructions
• Service Warnings
• Stock Locations
• Time Of Use
• Unit Of Measure
3. Configure message senders to pass messages with the integration layer.
Configure Administration Tables
This section describes unique setup issues related to configuring your system for the integration.
Activity Type
The codes defined here must exactly match values in the DVM for Order Type indicated. Refer to the section on FA Type for information on supported activity types.
Navigation
Guideline
Corresponding DVM
Admin Menu > Task Types
Create the activity types required by your business and populate the necessary information to define your set of activity types required for your business.
FS_Order_TypeCode.
Batch Processes
Batch jobs need to run to facilitate the transactions moving between the applications.
Navigation
Guideline
Admin Menu > Batch Control
Configure F1-SYNRQ to run every 5 - 10 minutes or at whatever time interval is appropriate. This is a Framework owned batch process but MWM uses it to send messages to the host system. It needs to run as often as these messages need to be sent.
Service Areas
The codes defined here must exactly match values in the DVM for Dispatch Group indicated.
Navigation
Guideline
Corresponding DVM
Admin Menu > Service Area
In Oracle Utilities Mobile Workforce Management the Service Areas are used to indicate areas where crews work on activities.
FS_Order_
DispatchGroup
The codes defined here must exactly match values in the DVM for Slot Group indicated. Refer to the section on Slot Group for information on supported Appointment Booking Groups.
Navigation
Guideline
Corresponding DVM
Admin Menu > Appointment Booking Group
Create the Appointment Booking Groups required by your business and populate the necessary information to define your set of Appointment Booking Groups required for your business.
FS_Order_
SlotGroup.
Configure Extendable Lookups
This section describes unique setup issues specifically related to configuring your system for the integration.
Disconnect Location
When a service point is disconnected from the supply source, a disconnect location must be specified. This location defines where service was severed. It also controls the type of field activity generated to reconnect service.
The codes defined here must exactly match values in the DVM for disconnect location code indicated.
Navigation
Guideline
Corresponding DVM
Admin Menu > Extendable Lookup > Disconnect Location
Define your disconnect location codes.
FS_Order_Disconnect
LocationCode
Every meter configuration must reference a meter configuration type. The meter configuration type indicates the valid (required or optional) unit of measure and time of use registers for the configuration.
The codes defined here must exactly match values in the DVM for meter configuration type indicated.
Navigation
Guideline
Corresponding DVM
Admin Menu > Extendable Lookup > Meter Configuration Type
Define your meter configuration types.
FS_Order_Meter
ConfigurationType
Meter Location
A meter can be associated with the on-site installation location.
Navigation
Guideline
Corresponding DVM
Admin Menu > Extendable Lookup > Meter Location
Define your meter location codes.
FS_Order_Meter
LocationCode
Stock Locations
A stock location is a physical or logical location at which meters and/or items are stored while they are not installed at a service point.
The codes defined here must exactly match values in the AIA configuration file for the Item and/or Meter Stock Location Codes indicated.
Navigation
Guideline
AIAConfigurationProperties.xml
Admin Menu > Extendable Lookup > Stock Location
Define stock location
codes.
FS_ItemStockLocationCode
FS_MeterStockLocationCode
Time of Use
Every meter register can be associated with a time of use code.
The codes defined here must exactly match values in the DVM for Register time of use indicated.
Navigation
Guideline
Corresponding DVM
Admin Menu >
Extendable Lookup > Time Of use
Define your time
of use codes.
FS_Order_RegisterTimeOfUseCode
Unit of Measure
Every meter register must be associated with a unit of measure (read type) code.
The codes defined here must exactly match values in the DVM for Read type indicated.
Navigation
Guideline
Corresponding DVM
Admin Menu > Extendable Lookup > Unit Of Measure
Define your unit of
measure codes.
FS_Order_RegisterReadUnitCode
Configure Message Senders
The following sections identify settings required to communicate using message senders.
Create the Outbound Message Type Used to Send Activity Status Updates to the Integration
Create a new Outbound Message Type which maps to the appropriate business object.
1. Navigate to Admin, Outbound Message Type, and select plus.
2. Enter a unique Outbound Message Type and Description (for example, CM-ACTSTATUS).
3. Populate values as follows:
Business Object = M2-ActivityStatusUpdate
Priority = 50. You can set this to any other value as needed.
Create the Outbound Message Type Used to Send Activity Completion Details to the Integration
Create a new outbound message type which maps to the appropriate business object.
For example, CM-ACTCOMPLT.
Business Object = M2-ActivityCompletionDetails
Priority = 50. You can set this to any other value.
Create the Outbound Message Type Used to Send Pickup Order (New Activity) Details to the Integration
2. Enter a unique Outbound Message Type and Description (for example, CM-NEWACTVTY).
Business Object = M2-ActivityDataDetails
Create the Outbound Message Type Used to Request Device Verification from the Integration
2. Enter a unique Outbound Message Type and Description (for example CM-DEVVERIFY).
Business Object = M2-DeviceVerificationMessage
Create an HTTP Sender for Pickup Orders
Create a new Message sender which points to the Oracle Utilities Mobile Workforce Management Requester ABCS for the Create Field Order integration point.
1. Navigate to Admin, Message Sender.
2. Enter a unique Message Sender and Description.
Invocation Type = Real-time
Message Class = RTHTTPSNDR. This is the class for real-time sender to route messages using HTTP.
MSG Encoding = UTF-8 message encoding
4. Select the Active check box.
5. Select the Context tab and set values for the following Context Types:
• Character Encoding – UTF-8
• HTTP Login User – User ID for the url to be accessed
• HTTP Login Password – Password for the url to be accessed
• HTTP Header – SOAPAction: "ProcessOrderCreate"
• HTTP Method (POST/GET) – POST
• HTTP Transport Method – SendReceive
• HTTP Timeout: 60 (in seconds)
• HTTP URL 1 – Set the URL to be accessed. If the URL value does not fit, use the additional HTTP URL types to set the complete URL. This should point to the Order Create Requester ABCS.
Example: http://[server]/services/default/ProcessWorkOrderCreateOUMWMUtilitiesReqABCSImplV2/ProcessWorkOrderCreateOUMWMUtilitiesReqABCSImplV2
Create an HTTP Sender for Activity Status Updates
Create a new Message Sender which points to the Oracle Utilities Mobile Workforce Management Requester ABCS for the Field Order Status Update integration point.
• HTTP Header – SOAPAction: "ProcessOrderStatus"
• HTTP URL 1 – Set the URL to be accessed. If the URL value does not fit, use the additional HTTP URL types to set the complete URL. This should point to the Order Status Requester ABCS.
Example: http://sdc60017sems.us.oracle.com:8095/soa-infra/services/default/ProcessWorkOrderStatusOUMWMUtilitiesReqABCSImplV2/ProcessWorkOrderStatusOUMWMUtilitiesReqABCSImplV2
Create an HTTP Sender for Activity Completion Details
Create a new Message Sender which points to the Oracle Utilities Mobile Workforce Management Requester ABCS for the Field Order Completion integration point.
• HTTP Header – SOAPAction: "ProcessOrderComplete"
• HTTP URL 1 – Set the URL to be accessed. If the URL value does not fit, use the additional HTTP URL types to set the complete URL. This should point to the Order Complete Requester ABCS.
Example: http://[server]/services/default/ProcessWorkOrderCompleteOUMWMUtilitiesReqABCSImplV2/ProcessWorkOrderCompleteOUMWMUtilitiesReqABCSImplV2
Create an HTTP Sender for Device Verification Messages
Create a new Message Sender which points to the Oracle Utilities Mobile Workforce Management Requester ABCS for the Validate Installed Product integration point.
4. Select the Context tab and set values for the following Context Types:
• HTTP Header – SOAPAction: "ValidateInstalledProduct"
• HTTP URL 1 – Set the URL to be accessed. If the URL value does not fit, use the additional HTTP URL types to set the complete URL. This should point to the Validate Installed Product Requester ABCS.
Example: http://[server]/services/default/ValidateInstalledProductOUMWMUtilitiesReqABCSImplV2/ValidateInstalledProductOUMWMUtilitiesReqABCSImplV2
Create an HTTP Sender for SP Query
Create a new Message Sender which points to the Oracle Utilities Mobile Workforce Management Requester ABCS for the SP Query integration point.
• HTTP Header – SOAPAction: "QueryInstalledProductList"
Example: http://[server]/services/default/ QueryInstalledProductListOUMWMUtilitiesReqABCSImplV2/QueryInstalledProductListOUMWMUtilitiesReqABCSImplV2
Create an External System
Create a new External System for the integration layer.
1. Navigate to Admin, External System.
2. Enter a unique External System and Description.
3. Set Our Name in Their System to MWM.
4. Add the four outbound message types created above.
• Activity Data Details Outbound Message Type - created above
• Processing method - Real-time
• Message Sender - new Message Sender for New Activities created above
• Date/Time Format - XSD
• Message XSL - AddSOAPEnvelopeAndNamespace.xsl
• Response XSL - M2DataDetails_Response.xsl
• Activity Status Update Outbound Message Type - created above
• Message Sender - new Message Sender for Activity Status Updates created above
• Activity Completion Details Outbound Message Type - created above
• Message Sender - new Message Sender for Activity Completion Details created above
• Device Verification Outbound Message Type - created above
• Message Sender - new Message Sender for Device Verification Messages created above
• Response XSL - M2DeviceVerification_Response.xsl
• Message Sender - new Message Sender for SP Query Messages created above
• Response XSL - RemoveSOAPEnvelopeAndNamespace.xsl
Manage Feature Configuration
1. Navigate to Admin > Feature Configuration.
2. Create new feature configuration with Schema Constants as the Feature Type and enter required values for the outbound message types you have created for this integration.
Option
Notes
Activity Status Outbound Message Type
Enter name of Activity Status Outbound Message Type created
Activity Completion Outbound Message Type
Enter name of Activity Completion Outbound Message Type created
New Activity Outbound Message Type
Enter name of New Activity Outbound Message Type created
Enter name of Device Verification Outbound Message Type created
Service Point Query Outbound Message Type
Enter name of Service Point Query Outbound Message Type created
