Choosing a Configuration Scenario for your Business
This integration supports several business models. The configuration of the product and its integration points is slightly different for each business model. This section is intended to help you decide which business model is likely to work best for your organization and which technical configuration is best suited to your chosen business model.
Every configuration scenario uses the integration layer to manage business processes and the flow of data between the applications.
Step by step configuration for each scenario is described in following sections.
Note: Some items are required for the general configuration of the participating application, but are not specifically required for the integration. You may already have these items configured if you use the application separately from the integration. Set these items according to the needs of your business and then populate the corresponding DVM accordingly.
Scenario 1: CC&B + MWM + WAM v1.9.1.x
Scenario 1: Integration + 3 edge applications are used to automate order to completion and billing.
• WAM v1.9.1.x Service Requests
• CC&B Field Activities
• MWM Activities
Application Product
Managed Functions
Notes
Oracle Utilities Customer Care and Billing
Field activities are created or updated by customer request, customer service representative action, automated process within the application, or from receiving integrated orders originated by other applications. These orders are sent to, or received from, the integration product as required by the business process.
Also configure customer and asset data synchronization - send.
Oracle Utilities Work and Asset Management v1.9.1.x
Service requests are created, updated, and in some cases completed. These orders are sent to, or received from, the integration product as required by the business process.
Also configure customer and asset data synchronization - receive.
Oracle Utilities Work and Asset Management v2.1.x
Not used.
Oracle Utilities Mobile Workforce Management
Activities originating from other applications are updated and completed. Pickup orders, related to other orders, are created. These orders are sent to, or received from, the integration product as required by the business process.
Implementation Guide
Order information and actions are received from the requester application. The orders are routed to the provider application(s) involved in the business process, based on the type of order and the action required. Information is enriched and transformed as needed by the participating applications. Error information is logged and communicated.
Scenario 2: CC&B + MWM
Scenario 2: Integration + 2 edge applications are used to automate order to completion.
• MWM Activities
Application Product
Managed Functions
Activities originating from other applications are updated and completed. ‘Pickup’ orders, related to other orders, are created. These orders are sent to, or received from, the integration product as required by the business process.
Not used.
Not used.
Scenario 3: MWM + WAM v1.9.1.x
Scenario 3: Integration + 2 edge applications are used to automate order to completion.
• MWM Activities
• WAMv1.9.1.x Service Requests
Application Product
Managed Functions
Not used.
Activities originating from other applications are updated and completed. Pickup activities, related to other activities, are created. These orders are sent to, or received from, the integration product as required by the business process.
Not used.
Scenario 4: CC&B + WAM v1.9.1.x
Scenario 4: Integration + 2 edge applications are used to automate order to completion and billing:
Application Product
Managed Functions
Notes
Not used.
Not used.
Scenario 5:MWM + WAM/ODM v2.1.x
Scenario 5: Integration + 2 edge applications are used to automate order to completion.
• MWM Activities
• WAM/ODM v2.1.x Activities
Application Product
Managed Functions
Not used.
Activities originating from other applications are updated and completed. Pickup activities related to other Activities, are created. These orders are sent to, or received from, the integration product as required by the business process.
Not used.
Activities are created, updated, and in some cases completed for distributed work. These activities for distributed work are sent to, or received from, the integration product as required by the business process.
Scenario 6:CC&B + WAM/ODM v2.1.x
Scenario 6: Integration + 2 edge applications are used to automate order to completion.
• CC&B Activities
Application Product
Managed Functions
Notes
Sp Synchronization available.
Not used.
Not used.
Scenario 7:CC&B + MWM + WAM/ODM v2.1.x
Scenario 7: Integration + 3 edge applications are used to automate order to completion.
• CC&B Activities
• MWM Activities
Application Product
Managed Functions
Notes
Not used.
