Managing Triggering Events and Retry Processing
This section explains the events in the edge applications that cause messages to be sent to the integration, and the actions required to fix issues.
In general, if any of the target applications returns an error while processing the inbound message the integration layer sends an e-mail notification is sent to the designated user and creates a work list entry.
The following sections describe possible error scenarios and how to resolve them.
CC&B Originated Messages
Order Create, Update or Cancel from Oracle Utilities Customer Care and Billing
Triggering Event
Creation, Update, or Cancellation of a field activity in CC&B with a Dispatch Group that is associated to an external system (this is controlled by an algorithm on Dispatch Group).
Retry for Business errors
If any of the target applications returns a business error while processing the inbound message, a negative acknowledgment is returned to CC&B. CC&B can be configured to create a To Do Entry on negative acknowledgments.
• If the error is caused because of missing configuration information, the user can fix the issue then resend the original message by changing the status of the message back to Pending. This is done on the Oracle Utilities Customer Care and Billing Notification Download table (using the Oracle Utilities Customer Care and Billing user interface). This sends another create, update or cancel message.
• If the error requires that something is changed on the field activity, the user can make updates to the data on the field activity in Oracle Utilities Customer Care and Billing to fix the business error. The update causes another outbound message (this time update) to be sent from Oracle Utilities Customer Care and Billing to the target application(s).
WAM v1.9.1.x Originated Messages
Oracle Utilities Work and Asset Management v1.9.1.x does not provide a mechanism to re-send failed messages.
Order Created from WAM v1.9.1.x
Triggering Event
Creation of a service request in WAM and the status of the service request changed to active.
The WAM user must cancel the service request and create a new one once the root cause of the issue has been fixed.
Order Updated from WAM v1.9.1.x
Triggering Event
WAM user updates either schedule date or problem description on the service request that was previously sent to the other application(s). This action sends send an update message.
WAM user can try resending the Update by making additional changes to the Problem Description on the service request after the root cause of the issue has been fixed.
Status Update FromWAM v1.9.1.x
Triggering Event
The status is changed on a service request that was previously sent to the other application(s). This sends a status update from WAM.
Once the root cause of the issue has been fixed, additional Status updates sent from WAM for the same order are sent successfully.
Order Cancellation From WAM v1.9.1.x
Triggering Event
The status on a WAM service request is changed to canceled.
The corresponding orders can be canceled manually in CC&B and/or MWM.
Order Completion From WAM v1.9.1.x
Triggering Event
The status on a WAM service request is changed to Finished.
There is no corresponding update required in CC&B or MWM.
Charge Create From WAM v1.9.1.x
Triggering Event
A WAM service request status changed to Closed and Billable Indicator is true.
The message can be resent from BPEL or it can manually be created in CC&B.
WAM/ODM v2.1.x v2.1.x Originated Messages
Oracle Utilities Work and Asset Management/Oracle Utilities Operational Device Management v2.1.x does provide a mechanism to re-send failed messages.
Order Create, Update or Cancel/Complete from WAM/ODM v2.1.x
Triggering Event
Creation, Update, or Cancellation/Completion of a Activity in WAM/ODM with an activity type that is associated to an external system.
If the target application returns a business error while processing the inbound message, a negative acknowledgment is returned to WAM.
If the error is caused because of missing configuration information, the user can fix the issue then resend the original message by clicking on the Resend button on the Activity page. This sends another create, update or cancel outbound message.
If the error requires that something is changed on the Activity, the user can make updates to the data on the Activity in Oracle Utilities Work and Asset Management to fix the business error. The user then clicks on the Resend button that causes another outbound message (this time update) to be sent from Oracle Utilities Work and Asset Management to the target application(s).
MWM Originated Messages
Pick-up Order Create From MWM
Triggering Event
Creation of Pick-Up Field Order in MWM for a Field Order that was earlier received from the integration.
If the Order failed in CC&B, the CC&B user can re-process the inbound order from the CC&B upload staging table after resolving the issue that caused it to fail.
If the order failed in WAM, it can be re-imported in WAM from the WAM interface table. This requires running an SQL in the WAM database.
Order Status Update From MWM
Triggering Event
Field Order status change in MWM send an update to CC&B.
The CC&B user can re-process the inbound order from the CC&B upload staging table after resolving the issue that caused it to fail.
Order Cancel From MWM
Triggering Event
Field Order cancellation in MWM and the integration sends an update.
If the transaction failed in CC&B, the CC&B user can re-process the inbound order from the CC&B upload staging table, after resolving the issue that caused it to fail.
If the transaction failed in WAM, it can be re-imported in WAM from the WAM interface table. This requires running SQL in the WAM database.
Order Completion From MWM
Triggering Event
Field Order is completed in MWM and the integration sends an update. The same update is triggered when a Pickup Order is completed.
If the transaction failed in CC&B, the CC&B user can re-process the inbound order completion from the CC&B upload staging table after resolving the issue that caused it to fail. If the transaction failed in WAM, it can be re-imported in WAM from the WAM interface table. This requires running SQL in the WAM database.
