Stopping and Starting NDS Polling
By default upon install, the field activities from Oracle Utilities Customer Care and Billing will not be picked up. The polling composite, GetNDSRecordsOUCCBUtilitiesEBF, does not poll the NDS records since <flagname> in the table OUCCB_NDS_PROCESS_ACTIVATION is set to ‘Stopped’.
Once all the integration configurations are completed, the polling can be started by running the composite ManageNDSRecordsUtilityEBF.
Using the ManageNDSRecordsUtilityEBF:
This composite is used to Start/Stop or check the status of the polling. Enter Details as needed:
Start: Starts the NDS processing
Stop: Stops NDS processing
Status: Gives status of Status and enableProcess (Ex: Status:Stopped::Flag:Yes)
