Property Name | Default / Shipped Value | Description |
Routing.ProcessNDSRecordOUCCBUtilities.EndPointURI | Points to Process NDS Record composite. | |
OU_CCB_01.ServiceProviderCD | AIASP | Service provider ID as defined in CC&B |
OU_CCB_01.MaxRecordsPerQuery | 100 | Maximum records in the portion returned by the query to NDS table |
OU_CCB_01.ProcessingDelay | 0 | The delay in seconds between each record processing |
Default.SystemID | OU_CCB_01 | System ID |
Routing.ExtractFAInfo.OU_CCB_01. EndpointURI | Points to Process ExtractFAInfo web service in CC&B | |
Routing.ProcessWorkOrderOUCCB UtilitiesReqABCSImpl.EndpointURI | Points to ‘Process Work Order’ FW PIP composite | |
ABCSExtension.PreInvokeExtractFAInfo | false | Customization – pre-invoke service ON/OFF switch. The actual endpoint is defined in ProcessNDSRecordOUCCBUtilitiesEBFExtension.wsdl. |
ABCSExtension.PostInvokeExtract FAInfo | false | |
Override.CreateXForm.ProcessWorkOrderOUCCBUtilitiesReqABCSImpl | false | Customization – override ‘Create’ FA XSL transformation ON/OFF switch. The override XSL is C1FAIntExtOrderCreate_Override.xsl in the composite source. Default is ‘false’. |
Override.UpdateXForm.Process WorkOrderOUCCBUtilitiesReq ABCSImpl | false | Customization – override ‘Update’ FA XSL transformation ON/OFF switch. The override XSL is C1FAIntExtOrderUpdate_Override.xsl in the composite source. Default is ‘false’ |
Override.CancelXForm.Process WorkOrderOUCCBUtilitiesReq ABCSImpl | false | Customization – override ‘Cancel’ FA XSL transformation ON/OFF switch. The override XSL is C1FAIntExtOrderCancel_Override.xsl in the composite source. Default is ‘false’ |
FAType_Create | FA-CRE | Create a Field Activity Type as defined in CC&B |
FAType_Update | FA-CHG | Update Field Activity Type as defined in CC&B |
FAType_Cancel | FA-CAN | Cancel Field Activity Type as defined in CC&B |
Default.SystemID | OU_CCB_ 01 | System ID |
