Performance Tuning
Note the following parameters which control performance for NDS records processing.
Defaults
Default settings provide reasonable values to start using the NDS records processing integration:
• PI = 60 sec
• D = 0 sec
• RP = 100
Parameter Definitions
• PI - Polling interval (the interval between the subsequent polling composite start times)
• To change, update properties using the Enterprise Manager.
1. Right-click the GetNDSRecordsOUCCBUtilitiesEBF composite entry.
2. Open Service/Reference Properties.
3. Select GetProcessActivationRecord adapter settings and update the ‘Polling Interval’ property.
• Increasing the PI value causes the system response to slow down, but less polling composite instances are created. You can set a proper polling interval value with Enterprise Manager depending on your current needs (a small one for better FA processing response or a bigger one suitable for FA bulk processing).
• D - Processing delay (the delay between each NDS record processing)
• Defined in AIAConfigurationProperties.xml.
• Increasing the D value slows down NDS record processing, but may make the other applications running on the same SOA server to operate more smoothly.
• RP - NDS Records portion size (how many records are extracted during each polling attempt)
• Increasing the RP value affects polling composite memory consumption, but it may be effectively used in combination with the PI setting to improve the overall performance.
