Installation
Complete the following installation steps:
1. Download the FieldworkPIP.zip file from Oracle Software Delivery Cloud. (https://edelivery.oracle.com).
Note: For specific instructions about installing this integration on non-Windows/ Linux platforms, see Oracle Support Knowledge Article ID 1349320.1.
2. Extract the zip file to SERVICES_LOCATION. Example: /u01/SERVICES_LOCATION/soainfra/apps
Note: Ensure that you have the write permissions and override the files during extraction. Unzip in such a a way that it should merge the contents of existing directory structure of SERVICES_LOCATION/soainfra/apps/../../../../till the child by installation zip (FieldworkPIP.zip )
Example:
Linux :
$ unzip FieldworkPIP.zip
When unzip finds a file that already exists in the destination (SERVICES_LOCATION/soainfra/apps/../../../../) , it asks if you want to overwrite it. You can then type y to overwrite it, A to overwrite all files.
When you unzip the following directories will be merged into SERVICES_LOCATION/soainfra/apps.
The extracted folder structure on the server should appear as:
Installing the Integration
1. Source the environment variables using aiaenv.bat/aiaenv.sh.
Windows:
C:\Oracle\Middleware\Oracle_Home\user_projects\domains\soa_doma in\soa\aia\bin\aiaenv.bat
Linux:
source
/Oracle/Middleware/user_projects/domains/soa_domain/soa/aia/
bin/aiaenv.sh
2. Open a command prompt and execute the following installation command in Linux or Windows respectively.
Linux:
ant -f $SOA_HOME/aiafp/Install/AID/AIAInstallDriver.xml - DDeploymentPlan=$AIA_HOME/pips/FieldWork/DeploymentPlans/ FieldWorkDP.xml -DPropertiesFile=$DOMAIN_LOCATION/soa/aia/bin/ AIAInstallProperties.xml - DSupplementaryDeploymentPlan=$AIA_HOME/pips/FieldWork/ DeploymentPlans/FieldWorkSupplementaryDP.xml - DDeploymentPolicyFile=$AIA_HOME/pips/FieldWork/DeploymentPlans/ FieldWorkConditionalPolicy.xml -l $AIA_HOME/pips/FieldWork/ DeploymentPlans/FieldWorkDP.log
Windows:
ant -f %SOA_HOME%\aiafp\Install\AID\AIAInstallDriver.xml -DDeploymentPlan=%AIA_HOME%\pips\FieldWork\DeploymentPlans\FieldWorkDP.xml -DPropertiesFile=%DOMAIN_LOCATION%\soa\aia\bin\AIAInstallProperties.xml -DSupplementaryDeploymentPlan=%AIA_HOME%\pips\FieldWork\DeploymentPlans\FieldWorkSupplementaryDP.xml -DDeploymentPolicyFile=%AIA_HOME%\pips\FieldWork\DeploymentPlans\FieldWorkConditionalPolicy.xml -l %AIA_HOME%\pips\FieldWork\DeploymentPlans\FieldWorkDP.log
This initiates a prompt for the WebLogic admin user name and password. Enter these details to initiate the installation.
Post-Installation Validation
After completing the installation steps, use the following guidelines to validate based on your planned integration combination.
Installation Validation for Scenario 1, Scenario 2 and Scenario 4
• Scenario 1: Integration + CC&B, MWM + WAMv1.x
• Scenario 2: Integration + CC&B + MWM
• Scenario 4: Integration + WAM v1.x + CC&B
1. Login to the Enterprise Manager console.
2. Navigate to SOA > soa-infra > default partition.
3. Verify that all composites are deployed and are in 'active' state. Following is a list of composites:
• AIAAsyncErrorHandlingBPELProcess
• AIAB2BErrorHandlerInterface
• AIAB2BInterface
• AIAErrorTaskAdministrationProcess
• AIAReadJMSNotificationProcess
• CCBGetMeterDataProvService
• CreateCustomerInteractionOUCCBUtilitiesProvABCSImpl
• CreateCustomerInteractionOUWAMUtilitiesReqABCSImpl
• CreateInvoiceOUCCBUtilitiesJMSConsumer
• CreateInvoiceOUCCBUtilitiesJMSProducer
• CreateInvoiceOUCCBUtilitiesProvABCSImpl
• CreateInvoiceOUWAMUtilitiesReqABCSImpl
• CreateTimeSheetOUWAMUtilitiesProvABCSImpl
• GetNDSRecordsOUCCBUtilitiesEBF
• GetWOLineApptWinAvailOUCCBUtilitiesReqABCSImpl
• GetWOLineApptWinAvailOUMWMUtilitiesProvABCSImplV2
• ManageNDSRecordsUtilityEBF
• ProcessNDSRecordOUCCBUtilitiesEBF
• ProcessWorkOrderCompleteOUMWMUtilitiesReqABCSImplV2
• ProcessWorkOrderCompleteOUWAMUtilitiesReqABCSImpl
• ProcessWorkOrderCreateOUMWMUtilitiesReqABCSImplV2
• ProcessWorkOrderCreateOUWAMUtilitiesReqABCSImpl
• ProcessWorkOrderOUCCBUtilitiesJMSConsumer
• ProcessWorkOrderOUCCBUtilitiesJMSProducer
• ProcessWorkOrderOUCCBUtilitiesProvABCSImpl
• ProcessWorkOrderOUCCBUtilitiesReqABCSImpl
• ProcessWorkOrderOUMWMUtilitiesJMSConsumerV2
• ProcessWorkOrderOUMWMUtilitiesJMSProducer
• ProcessWorkOrderOUMWMUtilitiesProvABCSImplV2
• ProcessWorkOrderOUWAMUtilitiesJMSConsumer
• ProcessWorkOrderOUWAMUtilitiesJMSProducer
• ProcessWorkOrderOUWAMUtilitiesProvABCSImpl
• ProcessWorkOrderResponseOUCCBUtilitiesJMSConsumer
• ProcessWorkOrderResponseOUCCBUtilitiesJMSProducer
• ProcessWorkOrderResponseOUCCBUtilitiesProvABCSImpl
• ProcessWorkOrderResponseOUMWMUtilitiesProvABCSImplV2
• ProcessWorkOrderResponseOUWAMUtilitiesProvABCSImpl
• ProcessWorkOrderStatusOUMWMUtilitiesReqABCSImplV2
• ProcessWorkOrderUpdateOUWAMUtilitiesReqABCSImpl
• QueryInstalledProductListOUCCBUtilitiesProvABCSImpl
• QueryInstalledProductListOUMWMUtilitiesReqABCSImplV2
• ReloadProcess
• UtilitiesCustomerInteractionEBS
• UtilitiesCustomerInteractionResponseEBS
• UtilitiesInstalledProductEBSV2
• UtilitiesInvoiceEBSV2
• UtilitiesWorkOrderEBS
• UtilitiesWorkOrderResponseEBS
• ValidateInstalledProductOUCCBUtilitiesProvABCSImpl
• ValidateInstalledProductOUMWMUtilitiesReqABCSImplV2
• ValidateInstalledProductOUWAMUtilitiesReqABCSImpl
• WAMGetMeterDataReqService
4. Login to the WebLogic admin console to validate.
• JMS queues and connection factories related to this integration are created under Home > JMS Modules > AIAJMSModule.
• AIA_OUCCBFAResponseJMSQueue
• AIA_OUCCBFAResponseJMSQueue_ErrorQ
• AIA_OUCCBInvoiceJMSQueue
• AIA_OUCCBInvoiceJMSQueue_ErrorQ
• AIA_OUCCBOUODMSPSyncReqQueue
• AIA_OUCCBOUODMSPSyncReqQueue_ErrorQ
• AIA_OUCCBWorkOrderJMSQueue
• AIA_OUCCBWorkOrderJMSQueue_ErrorQ
• AIA_OUMWMWorkOrderJMSQueue
• AIA_OUMWMWorkOrderJMSQueue_ErrorQ
• AIA_OUODMOUCCBSPSyncRespQueue
• AIA_OUODMOUCCBSPSyncRespQueue_ErrorQ
• AIA_OUWAMWorkOrderJMSQueue
• AIA_OUWAMWorkOrderJMSQueue_ErrorQ
• AIA_OUWAMAckResponseJMSQueue
• AIA_OUWAMAckResponseJMSQueue_ErrorQ
• AIAOUCCBCF
• AIAOUMWMCF
• AIAOUWAMCF
• Datasources related to integration are created under Home > Data Sources. This is applicable only if Oracle Utilities Customer Care and Billing is included in your integration.
• AIANDSDS
• AIAOUCCBNDSDS
5. Verify that the csf-keys are created successfully.
a. Login to the Enterprise Manager console.
b. Navigate to WebLogic_Domain > soa_domain.
c. Right-click soa_domain, and then select Security > Credentials.
d. Expand the oracle.wsm.security map.
e. Verify that the following keys are available:
• OU_CCB_01
• OU_MWM_01
• OU_WAM_01
• FW_PIP_01
The AIA_OUCCB_NDS_USER is created in the SOA database. The credentials for this user can be obtained from the AIAInstallProperties.xml file aiands node.
6. Verify the installation logs for any errors.
7. Get the configuration file from MDS using the GetFieldWorkConfigFileDP.xml utility and validate all the module level properties, service level properties are present in the AIAConfigurationProperties.xml.
Installation Validation for Scenario 3
• Integration + WAM v1.x + MWM
2. Navigate to the SOA > soa-infra > default partition.
• AIAB2BInterface
• OUCCBOUODMSPSyncReqEBF
• OUODMOUCCBSPSyncRespEBF
• ReloadProcess
4. Login to the weblogic admin console to validate the following.
• AIAOUCCBCF
• AIAOUMWMCF
• AIAOUWAMCF
b. Navigate to WebLogic_Domain > soa_domain > soa_domain.
• OU_CCB_01
• OU_MWM_01
• OU_WAM_01
• FW_PIP_01
The AIA_OUCCB_NDS_USER user is created in the SOA database. The credentials for this user can be obtained from the AIAInstallProperties.xml file aiands node.
Installation Validation for Scenario 5
• Integration + WAM v2.x + MWM
After the successful installation of the PIP for WAMV2-MWM the following composites will be successfully deployed and can be validated in the Enterprise Manageer Console.
3. Verify that all composites are deployed and are in 'active' state. Following is the list of composites:
• AIAB2BInterface
• ProcessWorkOrderCancelCompleteOUWAMUtilitiesReqABCSImplV2
• ProcessWorkOrderCreateUpdateOUWAMUtilitiesReqABCSImplV2
• ProcessWorkOrderOUWAMUtilitiesJMSConsumerV2
• ProcessWorkOrderOUWAMUtilitiesProvABCSImplV2
• ProcessWorkOrderResponseOUWAMUtilitiesJMSConsumerV2
• ProcessWorkOrderResponseOUWAMUtilitiesJMSProducerV2
• ProcessWorkOrderResponseOUWAMUtilitiesProvABCSImplV2
• ReloadProcess
4. Login to the weblogic admin console to validate. JMS queues and connection factories related to this integration are created under HOME > JMS Modules > AIAJMSModule.
• OU_CCB_01
• OU_MWM_01
• OU_WAM_01
• FW_PIP_01
Installation Validation for Scenario 6 and Scenario 7
• Scenario 6: Integration + WAM v2.x + CCB
• Scenario 7: Integration + WAM v2.x + CCB + MWM
• AIAB2BInterface
• ReloadProcess
4. Login to the WebLogic admin console to validate. JMS queues and connection factories related to this integration are created under HOME > JMS Modules > AIAJMSModule.
• AIA_OUCCBInvoiceJMSQueue_ErrorQQueue
• OU_CCB_01
• OU_MWM_01
• OU_WAM_01
• FW_PIP_01
