Configuring Edge Application Security Certificates in WebLogic
To import and configure the security certificates (such as CCB, WAMV2, MWM certificates):
1. Export the edge application certificate and save it on the integration server to add it to the key store.
Example: /Oracle/Middleware/Oracle_Home/user_projects/domains/ SERVICES_LOCATION/ccbcert.cer
2. Create a new keystore (example: UtilitiesIntegration.jks) for importing the edge application certificates.
Example:
keytool -genkey -keystore /Oracle/Middleware/Oracle_Home/wlserver/server/lib/ UtilitiesIntegration.jks -storepass xxxxxxx
3. Import the edge application certificates into the new trust store.
Example:
keytool -import -file /Oracle/Middleware/Oracle_Home/user_projects/domains/ SERVICES_LOCATION/ccbcert.cer -alias RootCA -keystore /Oracle/Middleware/Oracle_Home/wlserver /server/lib/ UtilitiesIntegration.jks -storepass welcome1
4. Verify if the certificate is added to the store using the following command by listing the certificates.
Example:
keytool -list -v -keystore /Oracle/Middleware/Oracle_Home/wlserver/server/lib/UtilitiesIntegration.jks
Enter the password when prompted.
5. Edit the file setDomainEnv.sh for Linux or setDomainEnv.cmd for Windows and replace the existing javax.net.ssl.trustStore property.
This is located in ${WL_HOME}/ user_projects/domains/<domain_name>/bin.
6. Search for -Djavax.net.ssl.trustStore in the file and replace it with Djavax.net.ssl.trustStore=${WL_HOME}/server/lib/UtilitiesIntegration.jks - Djavax.net.ssl.trustStorePassword=xxxxxxx.
7. In the WebLogic console, navigate to Home > Servers > soa_server1 > Keystores and configure the details.
8. Click Lock & Edit to change the keystore details.
9. Click Change and then select Custom Identity and Java Standard Trust from the drop-down list.
10. Enter the following values in the respective fields:
Custom Identity Keystore: /Oracle/Middleware/Oracle_Home/wlserver/server/lib/UtilitiesIntegration.jks
Custom Identity Keystore Type: jks
Custom Identity Keystore Passphrase: welcome1
Confirm Custom Identity Keystore Passphrase: welcome1
11. Click Activate Changes and bounce the managed server to bring the changes into effect.
Note: In a clustered environment, managed servers need to have their own keystore configured.
