AIAReadJMSNotificationProcessError
If the SOA version is 12.2.1 and the composite fails with the following error, deploy the composite AIAReadJMSNotificationProcess.
If the SOA version is 12.2.1 and the composite fails with the following error, deploy the composite AIAReadJMSNotificationProcess using the FieldWorkCustomDP.xml from SERVICES_LOCATION/soainfra/apps/services/sce/AIAReadJMSNotificationProcess
SCE composite AIAReadJMSNotificationProcess is failing with the following error message:
<bpelFault><faultType>0</faultType><runtimeFault xmlns="http://schemas.oracle.com/bpel/extension"><part name="summary"><summary>Problem evaluating XPath expression</summary></part><part name="code"><code>java.lang.RuntimeException</code></part><part name="detail"><detail>java.lang.RuntimeException: Problem evaluating XPath expression
at com.collaxa.cube.engine.xp.XP.exec(XP.java:220)
at com.collaxa.cube.engine.Script.exec(Script.java:111)
at com.collaxa.cube.engine.ext.bpel.v1.wmp.BPEL1SwitchConditionWMP.__executeStatements(BPEL1SwitchConditionWMP.java:74)
at com.collaxa.cube.engine.ext.bpel.common.wmp.BaseBPELActivityWMP$1.call(BaseBPELActivityWMP.java:197)
at com.collaxa.cube.engine.ext.bpel.common.wmp.BaseBPELActivityWMP$1.call(BaseBPELActivityWMP.java:195)
at com.collaxa.bpel.sws.SWSComponentProcessActivityWrapper$1.call(SWSComponentProcessActivityWrapper.java:74)
at com.collaxa.bpel.sws.SWSCallableActivityWrapper.execute(SWSCallableActivityWrapper.java:89)
at com.collaxa.bpel.sws.SWSComponentProcessActivityWrapper.execute(SWSComponentProcessActivityWrapper.java:82)
at com.collaxa.cube.engine.ext.bpel.common.wmp.BaseBPELActivityWMP.perform(BaseBPELActivityWMP.java:205)
at com.collaxa.cube.engine.CubeEngine.performActivity(CubeEngine.java:2878)
at com.collaxa.cube.engine.CubeEngine._handleWorkItem(CubeEngine.java:1260)
at com.collaxa.cube.engine.CubeEngine.handleWorkItem(CubeEngine.java:1155)
at com.collaxa.cube.engine.dispatch.message.instance.PerformMessageHandler.handleLocal(PerformMessageHandler.java:92)
at com.collaxa.cube.engine.dispatch.DispatchHelper.handleLocalMessage(DispatchHelper.java:300)
at com.collaxa.cube.engine.dispatch.DispatchHelper.sendMemory(DispatchHelper.java:379)
at com.collaxa.cube.engine.CubeEngine.endRequest(CubeEngine.java:4871)
at com.collaxa.cube.engine.CubeEngine.endRequest(CubeEngine.java:4795)
at com.collaxa.cube.engine.CubeEngine._createAndInvoke(CubeEngine.java:751)
at com.collaxa.cube.engine.CubeEngine.createAndInvoke(CubeEngine.java:586)
at com.collaxa.cube.engine.delivery.DeliveryService.handleInvoke(DeliveryService.java:723)
at com.collaxa.cube.engine.ejb.impl.CubeDeliveryBean.handleInvoke(CubeDeliveryBean.java:478)
at com.collaxa.cube.engine.ejb.impl.bpel.BPELDeliveryBean_5k948i_ICubeDeliveryLocalBeanImpl.__WL_invoke(Unknown Source)
at weblogic.ejb.container.internal.SessionLocalMethodInvoker.invoke(SessionLocalMethodInvoker.java:33)
at com.collaxa.cube.engine.ejb.impl.bpel.BPELDeliveryBean_5k948i_ICubeDeliveryLocalBeanImpl.handleInvoke(Unknown Source)
at com.collaxa.cube.engine.dispatch.message.invoke.InvokeInstanceMessageHandler.handle(InvokeInstanceMessageHandler.java:43)
at com.collaxa.cube.engine.dispatch.DispatchHelper.handleMessage(DispatchHelper.java:154)
at com.collaxa.cube.engine.dispatch.BaseDispatchTask.process(BaseDispatchTask.java:150)
at com.collaxa.cube.engine.dispatch.BaseDispatchTask.run(BaseDispatchTask.java:90)
at com.collaxa.cube.engine.dispatch.WMExecutor$W.run(WMExecutor.java:236)
at weblogic.work.j2ee.J2EEWorkManager$WorkWithListener.run(J2EEWorkManager.java:207)
at weblogic.invocation.ComponentInvocationContextManager._runAs(ComponentInvocationContextManager.java:348)
at weblogic.invocation.ComponentInvocationContextManager.runAs(ComponentInvocationContextManager.java:333)
at weblogic.work.LivePartitionUtility.doRunWorkUnderContext(LivePartitionUtility.java:54)
at weblogic.work.PartitionUtility.runWorkUnderContext(PartitionUtility.java:41)
at weblogic.work.SelfTuningWorkManagerImpl.runWorkUnderContext(SelfTuningWorkManagerImpl.java:617)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:397)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:346)
Caused by: javax.xml.xpath.XPathExpressionException: XPath Function {http://www.oracle.com/XSL/Transform/java/oracle.apps.aia.core.xpath.AIAFunctions}getSystemModuleProperty cannot be found.
at oracle.xml.xpath.JXPathExpression.evaluate(JXPathExpression.java:269)
at com.collaxa.cube.engine.xp.XP.exec(XP.java:201)
... 36 more
Caused by: javax.xml.xpath.XPathFunctionException: XPath Function {http://www.oracle.com/XSL/Transform/java/oracle.apps.aia.core.xpath.AIAFunctions}getSystemModuleProperty cannot be found.
at com.collaxa.cube.engine.xp.XPFunction.lookup(XPFunction.java:74)
at com.collaxa.cube.engine.xp.XPFunction.evaluate(XPFunction.java:53)
at oracle.xml.xpath.JXPathContext$JXFunction.invoke(JXPathContext.java:215)
at oracle.xml.xpath.JXPathContext$JXFunction.invoke(JXPathContext.java:182)
at oracle.xml.xpath.XPathExtFunction.evaluate(XPathExtFunction.java:335)
at oracle.xml.xpath.ComparisonExpr.evaluate(XSLExpr.java:1743)
at oracle.xml.xpath.JXPathExpression.evaluate(JXPathExpression.java:226)
... 37 more
</detail></part></runtimeFault></bpelFault>
