Password Expiry for Database
If a password expires or is changed connection issues may arise with the Meta Data Store, AIAOUCCBNDSDS, or integration specific database AIANDSDS.
To address this issue:
1. Reset the password or unlock the corresponding DB schema (MDS, NDS database, or integration specific database).
2. Change the password for the data source through the WebLogic Administration Console for the DB schema where the password is changed/locked.
3. Change the password in the AIAInstallationProperties.xml for DB schema.
This will be used when redeploying the integration using scripts.
