Validating the Uninstallation
Once the uninstallation is successfully completed, all of the composites should be removed from the Enterprise Manager console. Only the following composites that come as part of SCE in domain upgrade should remain:
• The credential map “oracle.wsm.security map” and keys “OU_CCB_01, OU_MWM_01, OU_WAM_01 and FW-PIP_01” created during installation should be deleted successfully.
• The JMS Queues and connection factories created during the installation from the weblogic console under HOME > MS Modules > AIAJMSModule should have been deleted.
• Data Sources related to your integration are removed and the user AIA_OUCCB_NDS_USER is dropped from the SOA database. This is applicable only if Oracle Utilities Customer Care and Billing is included as one of your edge application. Else, ignore.
