Managing Catalog Services
The catalog service is used by Oracle Integration Cloud to communicate with the respective application. It is used to identify the services that should be retrieved by the Oracle Utilities Adapter. It is configured in Catalog URL in the Oracle Integration Cloud connection.
To configure the catalog service in Oracle Utilities Work and Asset Cloud Service:
1. Login to Oracle Utilities Work and Asset Cloud Service.
2. Navigate to the Web Service Catalog page either from the Admin > [W or Integration] menu or from the Search menu.
3. Select REST Web Service Class.
4. Add the following REST inbound web services to the catalog:
Service Type
Service Name
Description
Inbound Web Service
W1-StockItemDetail
Manage Stock Item Detail
Inbound Web Service
W1-Storeroom
Manage Storeroom
External System
OUINT_ERP
Oracle ERP Application Integration
For more information about configuration, refer to the Oracle Utilities Work and Asset Cloud Service documentation available on Oracle Help Center at: https://docs.oracle.com/en/industries/energy-water/work-asset-cloud-service/index.html
Seasonal Time Shift
To configure the Seasonal Time Shift flag in Oracle Utilities Work and Asset Cloud Service:
2. Navigate to Admin > [W or Integration] menu > Install Options.
Alternatively, you can search the Install Options from the Search menu.
3. Select the Seasonal Time Shift flag.
