Importing an Oracle Accelerator Project from Oracle Integration Store
To import an Oracle accelerator project from Oracle Integration Store:
1. Navigate to the Oracle Integration Cloud Home page.
2. Click Browse Store.
3. In the store, search using any of the following keywords:
• UGBU
• WACS
• WAM
• SCM
• Work and Asset
• Supply Chain Management
• Storeroom
• Stock Item
4. Select “Oracle Utilities Work and Asset Cloud Svc. Integration to Supply Chain Mgmt” from the search results and click Get.
5. If applicable, choose the appropriate version.
6. Verify that the new project appears in the project list with the status “Configured” (this indicates connections are not yet completed).
7. Click Project Edit and follow the required verification and configuration steps. Refer to the Verifying the Project Import and Configuring Connections in Oracle Integration Cloud sections for instructions.
8. After configuration is complete, click Activate in the Design UI of the project.
Alternatively, you can also activate the latest deployment plan from the Deploy page of the project.
