Running the Extract Job
To run the Extract job:
1. From the toolbar on the right pane, click Manage Jobs > Manage Job Schedules.
2. Click Add.
3. Enter the Job Name, External Storage, Job Type, and Job Name. Click Save.
Note: The status should be “Succeeded”.
4. Login to UCM and search for the extracted files.
https://<Fusion application URL>/cs
a. Enter “subinv*” in the Quick Search and press Enter.
b. Click the respective ID and download the file. You will be able to see the CSV file as per the Subinventory extract mapping file in the BICC.
