Core Control Table Setup Sequence
To implement the system, you must set up your organization's business rules in "control tables". Setting up these tables is time-consuming because we allow you to tailor many aspects of the system to meet your organization's requirements. We strongly recommend that you take the time to document how you plan to set up all of these tables before you use the following roadmap to enter the core control data. Time spent understanding the interrelationships between this data will reap the rewards of a clean system that meets your current and long term needs.
While we describe the transactions and options in more detail in other sections of this manual, use the following chart (and the remaining sections of this chapter) as your roadmap. Here we list the order in which you perform tasks and the pages you'll use to set up your system. The order is important because some information must exist before other information can be defined (i.e., many dependencies exist).
Note:Auto setup. The Auto Setup column in the following table contains suggestions to save you time. It also indicates if a control table contains information when the system is installed.
Note:You don't have to set up every control table. You need only set up those control tables that govern functions that are applicable to your organization.
Function
Menu
Auto Setup
Global Context
Algorithm
Admin, Algorithm. You will need to set up an algorithm that populates global context values. The global context is used by various zones in the system to display relevant data. This algorithm is plugged-in on the installation record.
Accounting Environment
Country & State
Admin, Country
Currency Codes
Admin, Currency Code
USD is automatically populated
Accounting Calendar
Admin, Accounting Calendar
GL Division
Admin, General Ledger Division
Security Environment
Application Service
Admin, Application Service
All base package transactions are automatically populated
Security Type
Admin, Security Type
User Group
Admin, User Group
Note, you won't be able to set up users at this point
One user group, ALL_​SERVICES, is automatically setup. It references all other application services and a single user called SYSUSER.
Language
Admin, Language
ENG is automatically populated
Display Profile
Admin, Display Profile
Two display profiles are automatically setup: NORTHAM displays currencies and dates in a classic American format; EURO displays information in a classic European format
Data Access Role
Admin, Data Access Role
Access Group
Admin, Access Group
User
Admin, User
SYSUSER is automatically set up.
Note that you may import your users (and user groups) from an external source.
Return to User Group
You must return to your user groups and define all of their users
Customer Class Environment
Customer Class
Admin, Customer Class. At this point, you'll only be able to set up your customer class codes. You will return to these customer classes throughout the setup process to populate additional information.
Financial Transaction Environment
Work Calendar
Admin, Work Calendar
CIS Division
Admin, CIS Division
Revenue Class
Admin Revenue Class
Algorithm
Admin, Algorithm. You will need to set up the algorithm that constructs a distribution code's corresponding GL account when it is interfaced to the general ledger
Distribution Code
Admin, Distribution Code
Bank & Bank Accounts
Admin, Bank
Billable Charge Template
Admin, Billable Charge Template. Note, if you want the system to default service quantities onto billable charges created using this template, you must setup the appropriate unit of measure code, time-of-use code and/or service quantity identifier.
Billable Charge Upload Line Type
Admin, Billable Charge Line Type
Algorithm
Admin, Algorithm. You will need to set up several algorithms. These algorithms: 1) retrieve a bill segment's consumption, 2) calculate a bill segment's bill lines, 3) construct a bill segment's financial transaction, 4) cancel previously estimated bill segments
Bill Segment Type
Admin, Bill Segment Type
Algorithm
Admin, Algorithm. You may want to set up an algorithm that formats the Bill Segment information that is displayed throughout the system for a specific Bill Segment Type. This algorithm is plugged-in on the Bill Segment Type.
Algorithm
Admin, Algorithm. You will need to set up the algorithm that constructs a payment segment's financial transaction
Payment Segment Type
Admin, Payment Segment Type
Algorithm
Admin, Algorithm. You will need to set up the algorithm that constructs an adjustment's financial transaction
Algorithm
Admin, Algorithm. Several plug-in spots are available to perform additional logic when processing adjustments. For example, if you have the system calculate adjustments, you must set up an adjustment generation algorithm. Refer to Adjustment Type for other available plug-in spots that may be used by your implementation.
Algorithm
Admin, Algorithm. You may want to set up an algorithm that formats the Adjustment information that is displayed throughout the system for a specific Adjustment Type. This algorithm is plugged-in on the Adjustment Type.
Algorithm
Admin, Algorithm. You may want to set up an algorithm that formats the Adjustment information that is displayed throughout the system. This algorithm is plugged-in on the installation record.
Adjustment Type
Admin, Adjustment Type
Adjustment Type Profile
Admin, Adjustment Type Profile
Approval Profile
Admin, Approval Profile. Note, an approval profile references a To Do type and one or more To Do Roles; these must be set up before you can set up the approval profile. After the approval profile(s) are set up, they must be referenced on the adjustment types that they govern.
Cancel Reason - Bill
Admin, Bill Cancel Reason
Cancel Reason - Payment
Admin, Payment Cancel Reason
Cancel Reason - Adjustment
Admin, Adjustment Cancel Reason
Tender Type
Admin, Tender Type
Tender Source
Admin, Tender Source
A/P Request Type
Admin, A/P Request Type
Issuing Center
Admin, Issuing Center. You will need to set up issuing centers if your organization assigns document numbers to bills.
Installation
Admin, Installation Options - Framework and Admin, Installation Options. Many fields on the installation record impact the financial transaction environment. Refer to the description of the Billing and Financial Transaction pages and the Messages tab in the Framework page for more information.
Algorithm
Admin, Algorithm. You will need to set up an algorithm that distributes payments.
Algorithm
Admin, Algorithm. You will need to set up an algorithm that handles overpayment situations.
Algorithm
Admin, Algorithm. You may need to set up an algorithm if specific customers can have individual bill due dates.
Algorithm
Admin, Algorithm. You may need to set up an algorithm if you want the system to delete bills that contain only information about historical payments.
Algorithm
Admin, Algorithm. You may need to set up an algorithm if you want the system to levy a non-sufficient funds charge if a payment is canceled due to non-sufficient funds.
Algorithm
Admin, Algorithm. You will need to set up an algorithm that formats the bill information that is displayed throughout the system. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. You will need to set up an algorithm that formats the payment information that is displayed throughout the system. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. You will need to set up an algorithm that defaults the amount when a payment is manually added. This algorithm also calculates the amount of an automatic payment for a bill for an account with an active auto pay option. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. Refer to Customer Class for other available plug-in spots that may be used by your implementation to perform additional logic when processing payments and bills.
Return to Customer Class
Admin, Customer Class. You will need to plug-in the algorithms defined above on your customer classes.
Budget Environment
Algorithm
Admin, Algorithm. You will need to set up several algorithms at this time: How To Calculated The Recommended Budget Amount, How To Periodically True Up A Customer's Budget Amount, The Circumstances When The System Should Highlight A Customer As Having An Anomalous Budget.
Budget Plan
Admin, Budget Plan
Algorithm
Admin, Algorithm. Budget eligibility is set at the SA type level. You will need to set up an override budget eligibility algorithm if some service agreements for an SA type are not eligible for budget based on certain conditions.
Customer Environment
Account Management Group
Admin, Account Management Group. Note, you will probably have to set up To Do Type and To Do Roles before you can setup account management groups. Refer to Assigning A To Do Role for more information on how account management groups may be used to define an entry's role.
Account Relationship
Admin, Account Relationship Type
Alert Type
Admin, Alert Type
Bill Message
Admin, Bill Message
Algorithm
Admin, Algorithm. If you have software that's capable of reconstructing an image of a bill in a PDF (for the purpose of online display), you will need to create an algorithm that formats the extract records that are sent to your bill image software.
Bill Route Type
Admin, Bill Route Type
Contract Quantity Type
Admin, Contract Quantity Type
Algorithm
Admin, Algorithm. If you have software that's capable of reconstructing an image of a letter in a PDF (for the purpose of online display), you will need to create an algorithm that formats the extract records that are sent to your letter image software.
Letter Template
Admin, Letter Template
Customer Contact Class
Admin, Customer Contact Class
Customer Contact Type
Admin, Customer Contact Type
Conservation Programs
Admin, Conservation Program. You will need to set up conservation programs if your organization provides rebates to customers based on eligibility and verification of newly purchased appliances and hardware that are rated to conserve the demand for energy.
Algorithm
Admin, Algorithm. You may need to set up the algorithms that determine if person ID's are in a predefined format.
Person Identifier Type
Admin, Person Identifier Type
SICs
Admin, SIC Code
Tax Exempt Type
Admin, Tax Exempt Type
Algorithm
Admin, Algorithm. You may need to set up the algorithms that determine if phone numbers are in a predefined format.
Phone Type
Admin, Phone Type.
Person Relationship Type
Admin, Person Relationship Type.
Algorithm
Admin, Algorithm. You will need to set up an algorithm that formats the person information that is displayed throughout the system. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. You will need to set up an algorithm to validate a person's name. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. You can override the system's standard account information string by setting up an algorithm that produces this string of information. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. If you have software that's capable of reconstructing an image of a letter in a PDF for the purpose of online display, you will need to create an algorithm that renders this PDF. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. If you have software that's capable of reconstructing an image of a bill in a PDF for the purpose of online display, you will need to create an algorithm that renders this PDF. This algorithm is plugged-in on the installation record.
Installation
Admin, Installation Options. Many fields on the installation record impact the Customer Environment. Refer to the description of the Main, Person, and Account tabs for more information.
Statements
Algorithm
Admin, Algorithm. If you have software that's capable of reconstructing an image of a statement in a PDF (for the purpose of online display), you will need to create an algorithm that formats the extract records that are sent to your statement image software.
Statement Route Type
Admin, Statement Route Type
Statement Cycle
Admin, Statement Cycle
Algorithm
Admin, Algorithm. If you have software that's capable of reconstructing an image of a statement in a PDF for the purpose of online display, you will need to create an algorithm that renders this PDF. This algorithm is plugged-in on the installation record.
Automatic Payment (EFT) Environment
Algorithm
Admin, Algorithm. You will need to set up an algorithm to create automatic payments. This algorithm is plugged-in on the installation record.
Tender Source
Note: earlier, you created tender sources for the remittance processor and your cash drawers. At this point, you'll need to add at least one tender source for automatic payments. Why? Because automatic payments get linked to a tender control (which, in turn, gets linked to a tender source) when they are interfaced out of the system.
Algorithm
Admin, Algorithm. You will need to set up the appropriate automatic payment date calculation algorithm to populate the extract, GL interface and payment dates on automatic payments.
Auto Pay Route Type
Admin, Auto Pay Route Type
Tender Type
Admin, Tender Type
Note: earlier, you created tender types for things like cash, checks, etc. At this point, you'll need to add a tender type for each type of automatic payments (e.g., direct debt, credit card, etc.).
Work Calendar
Admin, Work Calendar. You need only set up additional work calendars if the auto pay sources (i.e., the financial institutions) have different working days than does your organization
Algorithm
Admin, Algorithm. If you need to validate the customer's bank account or credit card number, you will need to set up the appropriate validation algorithms.
Auto Pay Source Type
Admin, Auto Pay Source Type
Algorithm
Admin, Algorithm. You may need to set up an algorithm if your customers can define a maximum withdrawal limit on their autopay options.
Admin, Customer Class. You should plug-in the Autopay Over Limit Algorithm in each appropriate customer class.
Deposit Environment
Algorithm
Admin, Algorithm. You will need to set up several algorithms at this time: The Definition Of A Good Customer, When To Refund A Deposit To A Customer, When To Recommend An Additional Deposit, How / When To Calculate Interest, How To Generate The Recommended Deposit Amount.
Deposit Class
Admin, Deposit Class
Non Cash Deposit Type
Admin, Non Cash Deposit Type
Field Work Environment - Phase 1
Representative
Admin, Representative
Operation Area
Admin, Operation Area
Field Service Class
Admin, Field Service Class
Algorithm
Admin, Algorithm. You will need to set up the algorithms that execute special functions (if any) when a field activity is completed
Field Activity Type & Steps
Admin, Field Activity Type
Field Activity & Field Order Cancellation Reason
Admin, Fieldwork Cancel Reason
Field Activity & Field Order Reschedule Reason
Admin, Fieldwork Reschedule Reason
Algorithm
Admin, Algorithm. If you need anything special to happen when a remark is associated with a field activity (e.g., generate a To Do), you will need to set up an algorithm to do whatever you need to do and associate it with the respective Field Activity Remark.
Field Activity Remarks
Admin, Field Activity Remark
Algorithm
Admin, Algorithm. If you have software that's capable of reconstructing an image of a field order in a PDF (for the purpose of online display), you will need to create an algorithm that formats the extract records that are sent to your field order image software.
Dispatch Group
Admin, Dispatch Group
Disconnect Location
Admin, Disconnect Location
Field Activity Type Profiles
Admin, Field Activity Type Profile
Algorithm
Field activities for Start/Stop will only be created if the SA Type linked to the service point has a SASP field work creation algorithm. Refer to the SA Type section below.
Algorithm
Admin, Algorithm. If you have software that's capable of reconstructing an image of a field order in a PDF for the purpose of online display, you will need to create an algorithm that renders this PDF. This algorithm is plugged-in on the installation record.
Credit & Collections Environment (if you collect on overdue bills (as opposed to overdue debt), you will NOT set up these tables; refer to Overdue Processing - Set Up Tasks for the list of control tables required to collect on overdue bills)
Algorithm
Admin, Algorithm. You may need to set up algorithms if you have non-standard collection events.
Collection Event Type
Admin, Collection Event Type
Algorithm
Admin, Algorithm. You may need to set up a collection process cancellation algorithm if your organization allows individual service agreements to be removed from a collection process if they are paid (rather than performing cancellation based on all SAs in a debt class).
Collection Process Template
Admin, Collection Process Template
Collection Class
Admin, Collection Class
Algorithm
Admin, Algorithm. You will need to set up several algorithms at this time: Collection process cancellation criteria, Severance process cancellation criteria, and Override arrears due to pay plans.
Debt Class
Admin, Debt Class
Write Off Debt Class
Admin, Write Off Debt Class
Algorithm
Admin, Algorithm. You will need to set up Collection Condition algorithms.
Collection Class Control
Admin, Collection Class Control
Algorithm
Admin, Algorithm. You may need to set up algorithms if you have non-standard severance events.
Severance Event Type
Admin, Severance Event Type
Algorithm
Admin, Algorithm. You may need to set up a severance process cancellation algorithm if your organization allows a severance process to be canceled when the related service agreement is paid (rather than performing cancellation based on all SAs in a debt class).
Severance Process Template
Admin, Severance Process Template
Algorithm
Admin, Algorithm. You will need to set up several algorithms at this time: How to refer debt to a collection agency, How to transfer debt to another active service agreement, How to write down small amounts of debt, and How to refund credit balances to a customer.
Algorithm
Admin, Algorithm. You may need to set up algorithms if you have non-standard write-off events.
Write Off Event Type
Admin, Write Off Event Type (Note, you'll have to wait until you have defined your SA Types before you can set up the Write Off Events because SA Type is a necessary parameter to write off debt).
Write Off Process Template
Admin, Write Off Process Template
Write Off Control
Admin, Write Off Control
Collection Agency
Admin, Collection Agency. Note, each collection agency references a person therefore you must set up a person for each agency before you can enter collection agency information.
Algorithm
Admin, Algorithm. You may need to set up algorithms if you have special logic that should be executed when a pay plan is canceled.
Pay Plan Type
Admin, Pay Plan Type
Payment Method
Admin, Payment Method
Third Party Payor
Admin, Third Party Payor. Note, you must create an account before you can create a third party payor.
Installation
Admin, Installation. Several fields on the installation record impact the Credit & Collections Environment.
Algorithm
Admin, Algorithm. You will need to setup an algorithm that's called when a user write-off debt real time.
Services & Characteristics
Service Type
Admin, Service Type
Algorithm
Admin, Algorithm. If you have ad hoc characteristic types, you may need to set up the algorithms that control how they are validated
Foreign Key Reference
Admin, FK Reference. If you have foreign key characteristic types, you may need to set up foreign key references to control how the user selects the characteristic values (and how the foreign key values are validated).
All base package FK references are automatically populated
Characteristic Type & Values
Admin, Characteristic Type
Device Testing Environment
Algorithm
Admin, Algorithm. If you need to validate a specific device test component result, you will need to set up the appropriate validation algorithms.
Device Test Component Type
Admin, Device Test Component Type
Algorithm
Admin, Algorithm. If you need the system to determine if a device test's results are considered "passing", you will need to set up an algorithm to perform this processing.
Device Test Type
Admin, Device Test Type
Algorithm
Admin, Algorithm. If you have the system select meters / items for testing, you will need to set up an algorithm to perform this processing.
Meter & Item Environment
Meter Type
Admin, Meter Type [Note - you won't be able to define the collection of valid Equipment Types and Item Types until after you define the Item Types. You also will not be able to define the collection of Meter Configuration Types until after you define the Meter Configuration Types.]
Meter ID Type
Admin, Meter ID Type
Manufacturer / Model
Admin, Manufacturer
Unit of Measure
Admin, Unit of Measure
Time of Use
Admin, Time of Use
Admin, Meter Configuration Type
Retirement Reason
Admin, Retire Reason
Protocol
Admin, Protocol
Read Out Type
Admin, Read Out Type
Algorithm
Admin, Algorithm. You will need to set up an algorithm to generate estimated consumption.
Trend Area
Admin, Trend Area
Trend Class
Admin, Trend Class
High / Low
Admin, High Low Factor
Algorithm
Admin, Algorithm. You will need to set up an algorithm that calculates the high / low limits used on meter reads. This algorithm is plugged-in on the installation record.
Meter Location
Admin, Meter Location
Meter Read Instructions
Admin, Meter Read Instruction
Algorithm
Admin, Algorithm. If you need anything special to happen when a meter read with a given remark is uploaded (e.g., generate a field activity), you will need to set up an algorithm to do whatever you need to do and associate it with the respective Meter Read Remark.
Meter Reader Remarks
Admin, Meter Reader Remark
Meter Read Source
Admin, Meter Read Source
Meter Read Warning
Admin, Meter Read Warning
Item Type
Admin, Item Type
Algorithm
Admin, Algorithm. You will need to set up an algorithm to format the standard meter info that appears throughout the system. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. You will need to set up an algorithm to format the standard item info that appears throughout the system. This algorithm is plugged-in on the installation record.
Premise & Service Point Environment
Premise Type
Admin, Premise Type
Algorithm
Admin, Algorithm. You will need to set up an algorithm to format the standard premise info that appears throughout the system. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. You will need to set up an algorithm that formats the service point information that is displayed throughout the system. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. You may need to set up the algorithms that determine if geographic ID's are in a predefined format.
Geographic Type
Admin, Geographic Type
Service Point Type
Admin, SP Type. [Note - you won't be able to define the SP Type's SA Types until after you define the SA Types or the FA Type Profiles until after you define the Field Activity Type Profiles.]
Facility Level 1 to 2
Admin, Facility Level 1 to 2
Facility Level 2 to 3
Admin, Facility Level 2 to 3
Field Work Environment - Phase 2
Field Service Control
Admin, Field Service Control
Bill & Service Cycle Environment
Bill Cycle, Bill Cycle Schedule
Admin, Bill Cycle
Bill Period, Bill Period Schedule
Admin, Bill Period
Route Type
Admin, Route Type
Service Cycle / Route
Admin, Service Cycle
Service Schedule
Admin, Service Schedule
Rate Environment
Frequency
Admin, Frequency
Service Quantity Identifier
Admin, Service Quantity Identifier
Algorithm Type
Admin, Algorithm Type. If you create new pre-processing calculation rules, you must set up an algorithm type for each such rule (the algorithm type defines the types of parameters that are passed to the calculation rule).
All base package algorithm types are automatically populated
Bill Factor
Main, Rates, Bill Factor
Algorithm Type
Admin, Algorithm Type. If you create new Register Rules you must set up an algorithm type for each such rule (the algorithm type defines the types of parameters that are passed to the register rule).
Rate
Main, Rates, Rate Schedule
Calculation Group
Main, Rates, Calculation Group
Algorithm
Admin, Algorithm. If you use algorithms to dynamically change step boundaries, calculate prices, or implement calculation rule eligibility rules, you must set up these algorithms.
Calculation Rule
Main, Rates, Calculation Rule
Bill Factor Value
Main, Rates, Bill Factor Values
Bill Factor Interval Values
Main, Rates, BF Interval Values
Item Type SQ Estimate
Admin, Item Type SQ Estimate
Degree Day
Admin, Degree Days
Late Payment Environment
Algorithm
Admin, Algorithm. You will need to set up the algorithm that determine if customers in a customer class are eligible for late payment charges
Algorithm
Admin, Algorithm. You will need to set up the algorithm that levies late payment charges for customers in a customer class
Admin, Customer Class. You will need to plug-in the late payment charge algorithms set up above.
SA Configuration
Algorithm
Admin, Algorithm. You will need to set up the algorithms that determine:
• How to calculate the late payment charge amount for service agreements of a given type
• Special criteria to be tested before a service agreement is severed.
• How to create field activities for service agreements of a given type.
• Special processing that should take place prior to the completion of a bill that references service agreements of a given type.
• Special processing that should take place during completion of a bill that references service agreements of a given type.
• Special processing that should take place when service agreements of a given type are created.
• Special processing that should take place when a financial transaction is frozen for service agreements of a given type.
Algorithm
Admin, Algorithm. You may want to set up an algorithm that formats the SA information that is displayed throughout the system. This algorithm is plugged-in on the installation record.
Algorithm
Admin, Algorithm. You may want to set up an algorithm that formats the SA information that is displayed throughout the system for a specific SA Type. This algorithm is plugged-in on the SA Type.
Algorithm
Admin, Algorithm. If you want a Control Central alert to highlight when the current account has any stopped service agreement(s), you will need to set up the algorithm that does this. This algorithm is plugged-in on the installation record.
Service Agreement Type
Admin, SA Type
Terms and Conditions
Admin, Terms and Conditions
SA Type Start Options
Admin, SA Type Start Option
Update SP Types with initial SA types and with FA Type Profiles
Admin, SP Type
SA Relationships
SA Relationship Type
Admin, SA Relationship Type
Service Provider
Admin, Service Provider. Note, you must create a person before you can create a service provider. If you have financial relationships (you bill for them or they bill for you), you must also create an account and a financial settlement service agreement before you can create the service provider.
SA Type / SA Relationship
Admin, SA Type SA Relationship Type
Notification and Workflow
Workflow Event Type
Admin, Workflow Event Type
Workflow Process Template
Admin, Workflow Process Template
Notification Upload Type
Admin, Notification Upload Type
Workflow Process Profile
Admin, Workflow Process Profile
Notification External (Sender) ID's
Admin, Notification External ID
Notification Download Type
Admin, Notification Download Type
Service Provider.
Notification Download Profile
Admin, Notification Download Profile
Algorithm
Admin, Algorithm. If you want a Control Central alert to highlight when the current account and/or premise has active workflow processes, you will need to set up the algorithm that does this. This algorithm is plugged-in on the installation record.
Sales and Marketing
Order Hold Reason
Admin, Order Hold Reason
Order Cancel Reason
Admin, Order Cancel Reason
And more...
Refer to Campaign and Package Setup Sequence for additional setup requirements
Service Credit Membership
Algorithm
Admin, Algorithm. You may need to set up algorithms for the service credit membership type and service credit event type to control behavior for the service credit membership and its events.
Credit Unit
Admin, Credit Unit. If your service credits record non-monetary units.
Service Credit Membership Type
Admin, Service Credit Membership Type
Service Credit Event Type
Admin, Service Credit Event Type
Membership Inactive Reasons
Admin, SC Membership Inactive Reason
Wrap Up
Algorithm
#x2022; Special alerts on Control Central (assuming you have special alerts)
Admin, Installation Options - Framework and Admin, Installation Options. At this point, it's a good idea to double-check everything on the installation record.
Postal Default
Admin, Postal Code Default
If you have cash drawers you will also need to set up the following information:
• Create a person / account to which you will link your over / under service agreement. Refer How To Get An Unbalanced Tender Control In Balance (Fixing Over/Under) for more information.
• Create a service agreement to which your over/under payments will be linked. This service agreement will reference your over / under SA type. Refer to Over / Under Cash Drawer Segmentation for more information.
If you upload payments from an external source (e.g., a remittance processor or lock box), you must set up the following information:
• Create a person and account to which the system will link payments with invalid account. Refer to Phase 3 - Create Payment Events, Tenders, Payments and Payment Segments for information about the process that books invalid payments to this account. Refer to How To Transfer A Payment From One Account To Another for how a user transfers the payment from the invalid account to the correct account (once known).
• Create a service agreement for this account. This service agreement will reference your payment suspense SA type. The system needs this service agreement so that it can distribute the invalid account's payment (and this is necessary so that cash will reflect the payment). Refer to Payment Upload Error Segmentation for more information.
• Update the tender source associated with the respective source of payments to indicate the service agreement created in the previous step should be used for payments with invalid accounts. Refer to Setting Up Tender Sources for more information.
• Because the payment upload process simply books payments that reference invalid accounts to the account associated with the suspense service agreement on the payment's tender source, this account should belong to a customer class with the appropriate payment distribution algorithms. This may entail creating a new customer class that will only be used on suspense accounts. This customer class would need the following algorithms:
• We'd recommend using a simple payment distribution algorithm like PYDIST-PPRTY (distribute payment based on SA type's payment priority).
• We'd recommend using an overpayment distribution algorithm like OVRPY-PPRTY (distribute overpayment to highest priority SA type).
The remaining sections describe additional control tables that must be set up for specific functional areas.
