Meter Replicator
When a pallet of new meters arrives in your meter shop, you can use the meter replicator to quickly create many copies of a given meter and its configuration. The individual copies may then be edited as needed.
Perform the following steps to create multiple copies of a meter:
• Add a meter using Meter - Main Information.
• Add a meter configuration using Meter Configuration Maintenance.
• Use the meter replicator page to create copies of the meter and its configuration.
The topics in this section describe how to use the meter replicator. Note that there is also an Item Replicator in the case where you need to replicate other devices.
