Meter Configuration – Meter Configuration Portal
Select
and navigate to the Meter Configuration Portal page to view additional information associated with a Meter Configuration.Depending on your implementations requirements, you may define additional zones to appear on this Portal.
The contents of this section describe the zones that are available on this portal page.
General Information
Meter Configuration ID, Meter Configuration Info are displayed.
