Schema Constants - Feature Configuration
Create a feature configuration with the type Schema Constants. Populate entries for all the options listed below.
Only one. The system expects only one Schema Constants feature configuration to be defined.
Configure the options for your interaction with the outage system.
Your implementation may define additional options types. You do this by adding new lookup values to the lookup field F1CN_OPT_TYP_FLG.
Option |
Description |
Outage Call Contact Name Characteristic Type |
This is used to link the contact name of the caller associated with an outage call as a characteristic on the outage call. Refer to Define Characteristic Types for more information. Only one value is allowed for this option. |
Outage Call Contact Number Characteristic Type |
This is used to link the contact number of the caller associated with an outage call as a characteristic on the outage call. Refer to Define Characteristic Types for more information. Only one value is allowed for this option. |
Outage Call Identifier Characteristic Type |
This is used to link the call identifier supplied by the caller associated with an outage call as a characteristic on the outage call. Refer to Define Characteristic Types for more information. Only one value is allowed for this option. |
Outage Call Street Name Characteristic Type |
This is used to link the street name supplied by the caller associated with a fuzzy trouble call as a characteristic on the outage call. Refer to Define Characteristic Types for more information. Only one value is allowed for this option. |
Outage Call Cross Street Name Characteristic Type |
This is used to link the cross street name supplied by the caller associated with a fuzzy trouble call as a characteristic on the outage call. Refer to Define Characteristic Types for more information. Only one value is allowed for this option. |
Outage Call Block Number Characteristic Type |
This is used to link the block number supplied by the caller associated with a fuzzy trouble call as a characteristic on the outage call. Refer to Define Characteristic Types for more information. Only one value is allowed for this option. |
Outage Call City Characteristic Type |
This is used to link the city supplied by the caller associated with a fuzzy trouble call as a characteristic on the outage call. Refer to Define Characteristic Types for more information. Only one value is allowed for this option. |
Outage Call State Characteristic Type |
This is used to link the state supplied by the caller associated with a fuzzy trouble call as a characteristic on the outage call. Refer to Define Characteristic Types for more information. Only one value is allowed for this option. |
