Home Profile Module
The Bill Advisor Home Profile module summarizes a customer's home attributes, such as the dwelling type, cooling mechanism, and year the home was built. This information helps CSRs better understand a customer's context, and it can be updated by CSRs so that the utility has the latest data. There is also a section where CSRs can write supplementary notes about the customer's situation, which is ideal for capturing information not provided by the standard attributes.
Edit Icon: Users can click an edit icon to switch to edit mode and update the customer's home attributes. After an update is made, a callout is displayed to show who made the update and when, so that CSRs can advise customers on the accuracy of the information and determine if it needs editing. If a customer makes an update to their home attributes (for example, by updating their profile or by using the Oracle Utilities Opower web-based home energy audit tool), that update is reflected in the home profile widget, and the callout indicates that the customer is the one who made the change.
Any edits made to the home profile information will automatically be applied to other Oracle Utilities Opower products that use the same home profile information.Home Attributes List: The default list of attributes is shown below. The list can be configured to enable or disable attributes based on what is most relevant to a utility's customers.
- Owner or renter: Whether the customer rents or owns the home.
- Cooling mechanism: How the customer cools their home, such as central air conditioning, fan, or window units.
- Living area: The size of the home.
- Dwelling type: The home type, such as apartment or single family home.
- Has pool: Whether the customer has a pool on their property.
- Year built: The year the home was built.
- Heating type: How the customer heats their home, such as gas or electric.
- Notes: A blank section where other useful details about the customer can be added to help a CSR understand a customer's energy use. For example, this section is a good place to indicate if a customer is home all day or has a large appliance.
