Set Up Global Parameters
Specify the report parameter that you want to use across your Oracle Utilities Data Intelligence offerings.
- Sign in to your service.
- In the Oracle Utilities Data Intelligence Admin Console, click Reporting Configuration under Application Administration.
- On the Reporting Configuration page, click Global Parameters.
- In the Global Parameters region, in the Enterprise Calendar menu, select Gregorian.
- Click Save.
