Configure Custom Buckets - Asset
Facts and dimension attributes in the dimensional data model provided by Oracle Utilities Data Intelligence may contain numerical attributes that become more useful when grouping them into categories that represent specific number intervals. This process is often referred to as "binning" or "bucketing." For example, an age attribute value may be assigned to an age bucket such as < 1 Year, 1-5 Years, 5-10 Years, 10-20 Years, or >=20 years.
Utilities business applications support a set of predefined bucket business objects that are used in Data Intelligence. Intervals representing each bucket must be defined before the analytics solution can use bucket columns.
Bucket configuration does not prevent the definition of multiple buckets for a predefined bucket business object. However, only one bucket definition per bucket business object is supported.
Supported Buckets
Buckets must be configured by an administrator before they can be used by Data Intelligence. The following buckets are currently supported.
Dimension Importance Bucket Value Ranges (Examples) Column with Value to Be Bucketed Column Details
Dimension: Asset
Attribute: Condition Rating Bucket
Asset Condition rating is the assessment score that is calculated based on various assessments that are available for an asset.
Condition Rating Bucket will provide a meaningful illustration to users where condition rating can be structured in different buckets.
Example:
  • 0 to 1: Unrated
  • 1 to 2: Very Good
  • 2 to 3: Good
  • 3 to 4: Average
  • 4 to 5: Poor
  • 5+: Very Poor
W1_ASSET.CONDITION_RATING
Asset.Condition Rating
Bucket Column: Asset.Condition Rating Bucket
Business Object Name: Asset Condition Score Bucket Configuration
Business Object Code: W1-AssetConditionScoreBuckets
Dimension: Asset Location
Attribute: Criticality Bucket
Criticality defines the importance of the location in terms of the potential impact of having issues or problems at that location.
Criticality Bucket will provide a meaningful illustration to users where criticality can be structured in different buckets.
Example:
  • 0 to 4: Low
  • 4 to 7: Medium
  • 7 to 9: High
  • 9+: Critical
W1_NODE.CRITICALITY_FLG
Location / Organization.Criticality Flag
Bucket Column: Location / Organization.Criticality Flag Bucket
Business Object Name: Asset Criticality Bucket Configuration
Business Object Code: W1-AssetCriticalityBuckets
Dimension: Work Orders
Attribute: Work Priority Bucket
Work Priority defines the importance of the work in terms of the potential impact of not addressing issues. For example, emergency type work is a higher priority than routine maintenance work.
Work Priority Bucket will provide a meaningful illustration to users where work priority can be structured in different buckets.
Example:
  • 0 to 5: Low
  • 5 to 6: Normal
  • 6 to 7: High
  • 7 to 9: Urgent
  • 9+: Emergency
W1_WO.WORK_PRIORITY_FLG
Work Order.Work Priority Flag
Bucket Column: Work Order.Work Priority Flag Bucket
Business Object Name: Work Priority Bucket Configuration
Business Object Code: W1-WorkPriorityBuckets
  1. Sign in to the Oracle Utilities Work and Asset Management application.
  2. In the search bar at the top of the screen, search for the "Bucket Configuration" menu and open it.
    A search for the Bucket Configuration options within Work and Asset Management
  3. In the Description field, enter the percent symbol (%) to search for any predefined buckets.
    Page to enter the search criteria for locating bucket configurations with an example of searching based on the description value
    Note: A newly installed application will not have any default configurations. If there are any records available, results will be displayed based on the search criteria. Select any of the bucket configuration records returned from search results to navigate and view the configuration.
  4. To add a new bucket configuration, click Add at the top right of the page.
  5. Select an option from the Bucket Configuration Business Objects menu. These options represent the placeholder for the bucket definition.
    Display of the items available in the Bucket Configuration Business Objects drop-down list
  6. In the Bucket Configuration field, define the bucket configuration code and its description. The code must be unique and should reflect the purpose of the bucket. For example, if the purpose of the bucket is for binning Asset Condition Scores, then your bucket configuration code could be CM-CONDITIONSCORE, where CM is a prefix that identifies that it is custom, and where CONDITIONSCORE represents that it is for binning Asset Condition Scores.
  7. In the Bucket Value Ranges section, define a sequence of intervals for the start and end ranges that represents how the data should be grouped or binned. In most cases, the ranges must be continuous, and the start range must be the end range of the previous interval. The existing functionality will assign the attribute being binned into a range using the formula: Start Range <= x < End Range, where x is the numerical attribute being binned. The intervals must include all possible values of the underlying attribute that is binned into buckets. It is best practice to use a high value for the last end range to ensure that a large value is included in the interval defining the default bucket.
    Example of defining the bucket value ranges for a bucket configuration
Important Constraints: Follow these guidelines to avoid incorrect behavior of buckets.
  • Only one bucket configuration for each Bucket Business Object is supported by Analytics Visualization. Otherwise the application will return incorrect values and may double-count measures.
  • The bucket definition must have intervals that do not overlap and must cover all possible values. Otherwise, the application will return incorrect values and may under- or double-count measures.
