Define Standard Measurement Identifiers for AMI Data
Oracle Utilities Data Intelligence can perform data aggregation and enrichment on Advanced Metering Infrastructure (AMI) data extracted from your connected Meter Solution Cloud Service and Customer Cloud Service. Data is extracted using a Measurement Data Extract process, and can then be displayed in an AMI data dashboard.
Enabling the extract process requires defining the data to extract. This in turn involves defining the "standard measurement identifiers" used by Oracle Utilities Data Intelligence. Defining the identifiers must be completed in the Meter Solution Cloud Service and Customer Cloud Service. Implementers can then map those identifiers to specific combinations of Units of Measure (UOM), Time of Use (TOU), and Service Quantity Identifiers (SQI) for specific service types.
| Standard Measurement Identifier | Standard Service Type | Status | Description |
| E-KW | Electric | Active | Electric Kilowatt |
| E-KWH | Electric | Active | Electric Kilowatt Hours |
| E-KWH-CONS | Electric | Active | Electric kWh - Consumed |
| E-KWH-GEN | Electric | Active | Electric kWh - Generated |
| G-THERMS | Gas | Active | Gas Therms |
| W-CCF | Water | Active | Water - 100 Cubic Feet |
