Gather Basic Information
Prior to planning the implementation, gather essential information regarding your Oracle Utilities Data Intelligence implementation requirements to create an effective implementation plan. You will need information such as:
- The Oracle Utilities enterprise cloud applications you have subscribed to.
- The implementation status of each Oracle Utilities enterprise cloud application you have subscribed to.
- The date when each Oracle Utilities enterprise cloud application you subscribed to has data available for extraction.
- The requirement to implement Oracle Utilities Data Intelligence concurrently with the corresponding Oracle Utilities enterprise cloud applications.
- The requirement to implement enterprise applications such as Oracle Utilities Customer to Meter or Customer Cloud Service simultaneously or sequentially.
- The sequence of implementing Oracle Utilities enterprise cloud applications, if sequentially.
- The desired Oracle Utilities Data Intelligence implementation completion date.
- Oracle Utilities Data Intelligence Service Administrator
- Project Manager
Use a checklist to confirm that your action items are planned for. See the Gather Basic Information Checklist in the Fusion Data Intelligence documentation for an example of the type of checklist you can use.
