5 Configure Oracle Energy and Water Data Intelligence Data
As the cloud account administrator with the Functional Administrator or System Administrator application role, you specify the data load and reporting configuration details, and create data pipelines for functional areas that determine how the source data from Oracle Energy and Water Cloud Applications is loaded and displayed in Oracle Energy and Water Data Intelligence.
Any data you load into the autonomous data warehouse in Oracle Energy and Water Data Intelligence is subject to the data access controls that may not always match those in the source system.
For example, if User1 doesn't have the rights to access some data in your source system, then when you bring that data over to the autonomous data warehouse in Oracle Energy and Water Data Intelligence, this User1 can access that particular data. If you want to have the same controls on the data, then you must ensure that this particular User1 has the same data access rights as your source system in your Oracle Energy and Water Data Intelligence user setup.
