Typical Workflow to Set Up Oracle Energy and Water Data Intelligence
If you’re setting up Oracle Energy and Water Data Intelligence for the first time, then follow these tasks as a guide.
| Task | Description |
| Set up user access to Oracle Energy and Water Data Intelligence using single sign-on. | You can set up how users from Oracle
Energy and Water cloud applications access Oracle Energy and Water Data
sign-on. This setup simplifies how you manage user names and passwords.
It enables you to synchronize users and roles in Oracle
Energy and Water cloud applications with Oracle Identity Cloud Service and then enable
these users to access Oracle Energy and Water Data
Intelligence.
See Set Up User Access to Oracle Energy and Water Data Intelligence Using Single Sign-On. |
| Create an Oracle Energy and Water Data Intelligence instance. | Create a service instance to manage your cloud resources.
See Create an Oracle Energy and Water Data Intelligence Instance. |
| Verify your instance and sign in. | Verify your service instance when you receive an email from Oracle that your Oracle Energy and Water Data Intelligence service instance is ready. |
