Explore, Visualize, and Analyze Data
There are many ways that you can explore, visualize, and analyze data in Oracle Energy and Water Data Intelligence. You can create workbooks, add data elements, create and apply filters, and more. See Visualize and Analyze Data in the Oracle Analytics Cloud documentation for more information. You can also use the table below to find links to more specific tasks and instructions.
| Task | Description |
| Add notes to canvases and tie notes to specific data points | You can add notes to canvases and tie notes to specific data points. See Add Notes to a Visualization. |
| Use conditional formatting to highlight important data events in your visualizations | Use conditional formatting to highlight important data events in your visualizations so that you can take action. See Apply Conditional Formatting to a Visualization. |
| Update the settings for multiple columns of a dataset at the same time | Save time when changing settings for multiple columns. Multi-select columns in the Metadata view to change the Data Type, the Treat As setting, the aggregation type, and the hide setting for more than one column at once. See Configure Columns Properties in a Dataset. |
| Update the shared properties of all visualizations on a canvas at the same time | Multi-select visualizations on a canvas to easily change shared properties for groups of content. See Work with Multiple Visualizations on a Canvas. |
| Use improved sort options in Visualizations to clearly see the sort order and any sort conflicts | Sort data in a visualization by a column that's not included in the visualization. See Sort, Drill, Select Data, and Apply Statistics in Visualization Canvases. |
| Enter your own tooltip text to display when you hover over a visualization title | Enter your own tooltip text to display when you hover over a visualization title. See About Visualization Properties. |
