Turning On Revision Control
Revision control is turned off by default for maintenance objects that are configured for revision control.
Add the base package Checked Out zone to the Dashboard portal.
- Navigate to Portal.
- Search for the portal CI_DASHBOARD.
- In the zone list for the Dashboard portal, add the zone F1-USRCHKOUT.
Set up application security.
For users to have access to revision control, they must belong to a user group that has access to the application service F1-OBJREVBOAS.
Add the revision control algorithm to the maintenance object
that you want to have revision control.
This step must be repeated for each maintenance object that you want to have revision control.
- Go to the Maintenance Object page and search for the maintenance object that you want to have revision control.
- On the Algorithms tab of the maintenance object, add the revision control algorithm F1-REVCTL.
