Preparing the Staging Database
After the staging owner (STGADM), application user (STGUSER) and read access user (STGREAD) are created, install the initial database option in the staging schema. The rest of the steps are listed below.
To run the utility:
1. Set JAVA_HOME, PATH, and CLASSPATH.
Linux/UNIX:
export JAVA_HOME=/scratch/software/jdk1.8.0_291/
export PATH=$JAVA_HOME/bin:$PATH
export CLASSPATH=/../FW-V4.5.0.1.0-Oracle-Database- Multiplatform/FW/jarfiles/*
Windows:
SET JAVA_HOME=C:\Program Files\Java\jdk1.8.0_291
SET PATH=%JAVA_HOME%\bin:%PATH%
SET CLASSPATH= C:\FW-V4.5.0.1.0-Oracle-Database- Multiplatform\FW\jarfiles\*
2. Run Conversion from any directory making sure Step 1 is complete. Run the command as necessary.
Linux/UNIX:
If '-a' (apply on staging flag) is passed, it connects to the database as staging schema admin and performs the conversion setup, in addition to creation of the above files, by running the same SQLs present in the create* SQL files.
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -a -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
If '-r' (revert staging flag) is passed, it connects to the database as staging schema admin and reverts the staging to a state prior to conversion setup, running the same SQLs present in drop_* or restore_* SQL files.
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -r -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
To generate ONLY the scripts, the program should be invoked with '-s' parameter with no other flags (no '-a' or '-r' ):
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
Windows:
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d %{JDBC_CONN_STRING}% -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -a -s %{STG_ADMIN_USR}%,%{STG_ADMIN_PSWD}%,%{STG_RW_USER}%
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d %{JDBC_CONN_STRING}% -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -r -s %{STG_ADMIN_USR}%,%{STG_ADMIN_PSWD}%,%{STG_RW_USER}%
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d %{JDBC_CONN_STRING}% -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -s %{STG_ADMIN_USR}%,%{STG_ADMIN_PSWD}%,%{STG_RW_USER}%
It creates the following files in current directory (or output directory if passed as '-o') if '-r' (revert staging flag) is not passed.
After the staging schema has been set up, generate the security for the staging user following the steps in the
Configuring Security section.
Linux/UNIX:
java -Xmx1500M com.oracle.ouaf.oem.install.OraGenSec-d
<STAGING_DBUSER>,< STAGING_DBPASS>, jdbc:oracle:thin:@<DB_SERVER>:<PORT>/
<SID> -u <STAGING_RW_USER> -r <STAGING_RW_USER_ROLE>,< STAGING_R_USER_ROLE> -a A -p
<RW_USERPASS>
Windows:
"%JAVA_HOME%"\bin\java -Xmx1500M com.oracle.ouaf.oem.install.OraGenSec -d < STAGING_DBUSER>,< STAGING DBPASS>, jdbc:oracle:thin:@<DB_SERVER>:<PORT>/
<SID> -u < STAGING RW_USER> -r <STAGING RW_USER_ROLE>,<STAGING R_USER_ROLE> -a A -p
<STAGING_RW_USERPASS>
