Bug Number | Description |
Oracle Utilities Customer Care and Billing | |
31538164 | CHANGE THE RESOURCE URI COMPONENT TO PLURAL(CUSTOMERCONTACT TO CUSTOMERCONTACTS) AND ADD UNDERSCORE TO DATA LIST |
33083792 | COPY OF 32902868 - CASE TYPE: PIN - CHARACTERISTICS ARE NOT PROPERLY SORTED |
33766833 | COPY OF BUG 33746806 - PAYMENT REJECTED ALERT IS BEING DISPLAYED MULTIPLE TIMES |
34244161 | COPY OF 33998076 - INCORRECT INITIAL AND CLOSING ESTIMATED BILL SEGMENT PERIOD |
34281955 | COPY OF 34165600 - RATE SCHEDULE TREE DOES NOT SHOW UP FOR CERTAIN COMBINATION |
34292910 | COPY OF 34292441 - ANSWER TEXT IN DATE/TIME FORMAT IS SAVED BASED FROM DISPLAY PROFILE |
34310515 | COPY OF 34310334 - COMPILE ERROR IN PROCESS NOTIFICATION INSTANCE (C1PRCNTFINST) SCRIPT |
34311406 | COPY OF 33912467 - COPY OF 33578816 - URI WHITELIST VALIDATION ERROR WHILE RUNNING BATCH RTTYPOST |
34326197 | COPY OF 32560145 - MEASUREMENT NOT FOUND FOR MEASURING COMPONENT |
34327089 | REMOVE WEB USER ROLE VALIDATION FROM CONNECTED ACCOUNTS APIS |
34330626 | NOTIFICATION EVENT TYPE MO - FIXES |
34331728 | COPY OF 34120693 - LANDLORD REVERSION ALGORITHMS ALWAYS EXECUTING EVEN AFTER IT IS SET TO NOT REVERT |
34349484 | COPY OF BUG 34142762 - SWITCHING TO PAPERLESS BILLING IS NOT WORKING ON TRANSFER SERVICE PROCESS FLOW [MAIN] |
34353894 | COPY OF 34278943 - CASE FILTER IS SHOWING OTHER CASE TPE OTHER THAN THE ONE SELECTED |
34355755 | COPY OF 30051059 - C1-SMSYX NOT EXTRACTING RECORDS IN SEQUENCE OF METER REMOVE FOLLOWED BY METER INSTALL |
34356526 | COPY OF 34356507 - INSIGHT - HIGHLIGHT OPEN SERVICE CALL - NPE |
34357506 | COPY OF 34269681 - RES START SERVICE AUTO PAY - NAME FIELD IS REQUIRED [MAIN] |
34357526 | COPY OF 33721286 - DIFFERENCE IN BEHAVIOR OF RATING ENGINES BETWEEN C2M / BCS VS CCB 2.4 |
34363807 | SERVICE CALL PROCESS FLOW - VALIDATE ADDRESS NOT HIDDEN |
34373156 | COPY OF 33503705 - CUSTOMER INSIGHT IS NOT WORKING ON SOME CONTROL CENTRAL ALERTS |
34374753 | COPY OF 33989494 - THE SA ROLE FLAG(SPR_MKT_OPT_SA_ROLE_FLG) IN C1PAYMSPR ALGORITHM SHOULD BE MADE AS CONFIGURABLE |
34376800 | COPY OF 34036834 - SA PROCEEDS TO BE BILLED EVEN IF SA TYPE'S BILL ELIGIBILITY IS 'INELIGIBLE' |
34378005 | COPY OF 34325635 - UNABLE TO SAVE SOFT PARAMETERS FOR SOME BATCH CONTROLS |
34383157 | COPY OF 34091273 - PAYMENTUS ISSUES |
34385965 | COPY OF 34332619 - EXISTING PERSON IDENTIFIERS SHOULD BE MASKED |
34390632 | COPY OF 34337163 - DEADLOCK ISSUE ADDING/REMOVING LANDLORD FOR PREMISE MANAGEMENT |
34393661 | COPY OF 34385235 - SERVICE CALL ID IS EXPECTED INSTEAD OF SERVICE CALL NUMBER |
34396601 | COPY OF 34198232 - DEACTIVATE BUTTON IS NOT WORKING IN THE SELF-SERVICE TASK PORTAL |
34416194 | COPY OF 33840907 - WHEN STARTING SA WITH START PREMISE SPS START METHOD, ALLOW ESTIMATES NOT DEFAULTED FROM SA TYPE [MAIN] |
34457774 | COPY OF 34333283 - PROCESS FLOW: CONTACT DETAIL VALUE IS NOT FORMATTED WHEN ADDING A NEW PERSON CONTACT |
34458015 | COPY OF 34305107 - UPGRADE EXISTING PA REQUEST WITH CHARACTERISTICS |
34458199 | COPY OF 34328014 - PROCESS FLOW: UNABLE TO PROVIDE CUSTOMER CONTACT COMMENT IN STOP SERVICE [MAIN] |
34459161 | COPY OF 34319281 - CSR STOP SERVICE: NON-SP BASED SAS ARE NOT SHOWING UP ON SERVICES TO STOP PANEL |
34476634 | COPY OF 34418178 - CONVERSION- NEED ABILITY TO INSERT CI_ADJ_CALC_LN RECORDS INTO CISADM SCHEMA |
34483539 | COPY OF 34252500 - 2.8 - CUSTOMER 360 PORTAL - CUSTOMER ACTIVITY HISTORY ZONE IS TIMING OUT |
34485988 | COPY OF 34418543 - SA TYPE SPECIAL ROLE FLAG CANNOT BE SET IF SA TYPE OPTION EXISTS |
34502015 | COPY OF 34360867 - PROCESS FLOW: ERROR IS RAISED WHEN MULTIPLE PERSON CONTACTS ARE PROVIDED [MAIN] |
34521217 | COPY OF 34493068 - IN REDWOOD THE PERSON ID DOES NOT POPULATE ON ACCOUNT MANAGEMENT |
34522212 | CCB 29010 - AT LEAST 1 START OPTION MUST BE SELECTED FROM THE LIST OF START OPTIONS ON SST W/O SA TYPE START OPTION |
34525717 | COPY OF 34206169 - CMA ISSUES |
34527810 | COPY OF 31927996 - ISSUE WITH CALC RULE ELIGIBILITY CRITERIA WHEN SA HAS ABOLISHED AND ACTIVE SP'S |
34544471 | COPY OF 34506757 - CMTPRCSH - BATCH PERFORMANCE. INDEX REQUEST AND RECOMMENDATION REQUEST. |
34544957 | FINANCIALHISTORY API IS RETURNING INCORRECT HASMORE AND TOTALRECORDS VALUE IN THE RESPONSE WHEN A QUERY PARAM IS PROVIDED |
34551603 | COPY OF 33973617 - RIGHTNOW MASTER CONFIGURATION ISSUE |
34553669 | COPY OF 34077791 - UNABLE TO COMPLETE THE CUSTOMER SERVICE REQUEST OF THE STOP SERVICE |
34563710 | COPY OF 34090570 - POS ID CHECK ALGORITHM EXTENSION |
34567903 | COPY OF 34538657 - DUPLICATE SYNC REQUESTS SHOWING IN SYNC REQUEST SEARCH RESULTS [MAIN] |
34568552 | COPY OF 34495499 - START/STOP/TRANS REQUESTS THROW SYSTEM ERROR WHEN THE ACCT-PER HAS ADDRESS SOURCE SET AS ACT OVERIDE |
34570269 | COPY OF 34344035 - ACCOUNT CONTEXT ADD CASE MENU DOES NOT RESTRICT CASE TYPES BY CIS DIVISION |
34606459 | COPY OF 34535875 - UI ISSUES IN ACCOUNT MANAGEMENT PAGE FROM CONTROL CENTRAL PAGE IN REDWOOD |
34614558 | COPY OF 33922551 - DSS-DYNAMIC ERROR HANDLING FOR BILLING PROGRAMS,CHECKING ELIGIBILITY FOR PAYMENT EXTENSIONS |
34621690 | COPY OF 34258507 - BUG 33084635 HAS CREATED FEW MORE PROBLEMS TO THE CUSTOMER |
34627442 | COPY OF 34580678 - ELECTRIC SA IS NOT AN OPTION IN THE START/STOP WINDOW |
34645440 | COPY OF 34376517 - ADD ROOT NODE FUNCTIONALITY TO XML BILL PRINT EXTRACT |
34647186 | COPY OF 33668719 - CIPPDACN/CIPPDSAN COMMON ROUTINES |
34653313 | COPY OF 34548046 - SERVICE DOES NOT REVERT BACK TO THE LANDLORD ACCOUNT AFTER INITIATING STOP ON THE TENANT ACCOUNT |
34656180 | COPY OF 34595308 - APAY-CREATE ALGORITHM CALCULATES INCORRECT AMOUNT AFTER CREDITS WERE TRANSFERRED TO OVERPAYMENT SA |
34668612 | COPY OF 31511741 - GL SUMMARY OF STATISTICAL AMOUNT IS PASSING INCORRECT VALUE DOUBLING OF THE CONSUMPTION [MAIN] |
34700638 | COPY OF BUG 34172492 - MULTI DIVISION CONFIGURATION ISSUES |
34705442 | COPY OF 34538319 - CCB JOB STREAM CREATION SCHEDULE MAINTENANCE OBJECT NOT FOUND SINCE HOT FIX ROLL UP |
Oracle Utilities Meter Data Management | |
33959056 | BUG 33959056 - COPY OF BUG 33902694 - COPY OF BUG 33902691 - COPY OF 33601095 - UNABLE TO FORCE COMPLETE AN IMD IN EXCEPTION STATUS |
34326123 | COPY OF BUG 34326121 - COPY OF BUG 34280507 - MEASUREMENT REPROCESSING NOT WORKING ON ACTIVE INSTALL EVENT WHEN THERE ARE MULTIPLES IES |
34355641 | COPY OF BUG 34322823 - ERROR MESSAGE "COMBINATION, NOT FOUND" WHEN FACTOR IS DELETED |
34360583 | COPY OF BUG 34360349 - THE EXCEPTIONS ARE THROWN AGAIN WHEN USING THE COMPLETE BUTTON |
34362493 | COPY OF BUG 34362486 - COPY OF BUG 34362480 - COPY OF BUG 34090654 - 21B: SCALAR - INITIAL MEASUREMENT OVERLAY ZONE EXCEPTION |
34363084 | COPY OF BUG 34363079 - COPY OF BUG 34363075 - COPY OF BUG 34363074 - COPY OF BUG 34190075 - PROD: LATEST MEASUREMENT DATE TIME IS NOT PROPERLY POPULATED AND IS CREATING ISSUES IN PE NOT FIL |
34364108 | COPY OF BUG 34316734 - MEASURING COMPONENT QUERY NOT FILTERING CORRECTLY TO SPECIFIC MC IN SEARCH RESULTS |
34372038 | COPY OF BUG 33903471 - IMD EXCEPTION PERCENTAGE OF MISSING INTERVALS EXCEEDING A LIMIT |
34372039 | OUMDM-26418 SUBSCRIPTION CHARACTERISTICS |
34372051 | COPY OF BUG 34112695 - D2-MATH WITH METER EXCHANGE CHANGES CONDITIONS TO NO READ BEFORE THE EXCHANGE |
34372157 | COPY OF BUG 34372151 - COPY OF BUG 34372149 - COPY OF BUG 34332030 - PORTALS ARE AUTO SCROLLING DOWNWARDS UPON LOAD |
34376523 | COPY OF 34376492 - REMOTE DISCONNECT COMMAND COMPLETES WITHOUT EXECUTING ITS COMPLETION EVENT |
34377342 | COPY OF 34261202 - ON DEMAND SCALAR READ NOT PROCESSING INTO C2M |
34382420 | COPY OF 34382415 - COPY OF 34382410 - COPY OF 34376734 - CHANGES TO COMMON ROUTINE SCALAR CONSUMPTION RETRIEVER CAUSES SCALAR 360 ISSUES |
34386090 | COPY OF 34386063 - COMMAND REQUEST ACTIVITY IS NOT BEING HANDLED CORRECTLY EVEN AFTER INSTALLING THE BUG 34044709 |
34391507 | COPY OF BUG 34391506 - COPY OF ENH 34066071 - MEASUREMENT REPROCESSING ISN'T INITIATED WHEN THE INSTALL EVENT DATES ARE CHANGED |
34392940 | COPY OF BUG 33925355 - UPDATING BADGE NUMBER IN ODM CAUSES SYNC ERROR WITH NO UPDATE TO CONFIGURATION EFF DATE/TIME |
34421067 | COPY OF BUG 34420994 - ROUTE MANAGEMENT IN CCS PRODUCTION IS NOT DISPLAYING THE SEQUENCE IN ORDER |
34435961 | COPY OF BUG 34270262 - COPY OF BUG 34270260 - COPY OF BUG 34200266 - NEGATIVE CONSUMPTION RETURNS SYSTEM ERROR |
34436645 | COPY OF 34436629 - ON DEMAND READ ACTIVITY FAILING ON MDM PROD AND GETTING ROLLED BACK FROM OOB ALGO |
34461124 | SEARCH BUTTON PLACEMENT IN APPOINTMENT BOOKING ZONE IS NOT SAME AS FW STYLE |
34467993 | COPY OF BUG 34467990 - COPY OF BUG 34467988 - COPY OF BUG 34159659 - INSTALL CONSTANT OF 80.0 ISN'T FACTORING INTO KW/KVAR READS |
34488791 | CORRECT FIELDS MARKED AS 'FLAG' W/O CORR LOOKUP |
34490024 | COPY OF BUG 33965940 - NPE FIXED FOR ONLY D1-SPT-CRTFD BUT NOT D1-IMD-CRTFD AFTER PATCH 33535531 APPLIED |
34490031 | COPY OF BUG 34110219 - COPY OF BUG 34110215 - METER READ DOWNLOAD ACTIVITY INFO STRING CAUSES CONFUSION ON DEVICE ACTIVITIES ZONE |
34490066 | COPY OF BUG 33925286 - SYSTEM ERROR USING BASE USAGE CALCULATION RULE ELIGIBILITY CRITERIA D1-SP-URCF |
34490170 | COPY OF BUG 34058175 - D1-ARSPE ALGORITHM GENERATED A WRONG END DATE/TIME IN THE FIRST PERIODIC ESTIMATE IMD OF SCALAR MC |
34493551 | DELETE UI_PROG_COM_ID IN CI_MD_MO |
34493590 | INVALID PROG COM ON HELP NAV KEY (D2TOTRPAGE_H) |
34494624 | COPY OF BUG 34478188 - ILM DATE IS SET TO PROCESS DATE WHEN CONVERTING CCB TO MDM/ODM COMPONENTS |
34496125 | D1-SIMDI - APPLICATION PROVIDES INCORRECT ERROR MESSAGE WHEN USER IS MISTAKENLY PROVIDING STOP DATE/TIME IS GREATER THAN START DATE/TIME |
34505928 | COPY OF 34505916 - AUTOACTIVATE FLAG IS NOT POPULATING IN THE SGG SSN ADDMETERREADJOB (SCALAR AND INTERVAL) REQUESTS |
34514022 | MISSING BO OPTION ON D7-METERREADRESPONSESCALAR |
34520720 | MISSING BO OPTION ON D7-METERREADRESULTSSCALAR |
34523632 | 34523632 COPY OF BUG 34523621 - APPOINTMENT BOOKED AND SHOWN IN ACTIVITY IS ONE HOUR LATER THAN THE SLOT CHOSEN. |
34525020 | COPY OF 34525017 - COPY OF 34525010 - COPY OF 34461648 - BILL SEGMENT GIVING SYSTEM ERROR (NULLPOINTER EXCEPTION) WHEN CREATING AN USAGE REQUEST |
34529624 | COPY BUG 33322298 OF ISSUE IN METER OPERATIONAL DASHBOARD - USER INTERFACE ISSUE |
34538630 | SCHEMA CHANGES TO SUPPORT ODM-MDM ON OIC |
34557244 | COPY OF 34557242 - CCS TO ITRON ON-DEMAND SCALAR READ REQUESTS ARE RETURNING DEMAND READS, BUT THEY ARE NOT LOADING |
34560805 | COPY OF 34640293 CHANGE 'NO DATA FOUND FOR XPATH' FROM ERROR TO INFO |
34576320 | COPY 34509794 OF ARRAY MATH DOESN'T USE D1_AGG_MSRMT |
34584817 | COPY OF BUG 34584812 - COPY OF BUG 34584806 - COPY OF BUG 34550601 - CASE WHERE SUBTRACTIVE INTERVAL FORCE COMPLETE ALLOWS BAD QTY AFTER OUT OF ORDER/EXCEPTION PROCESSING |
34584992 | COPY OF 34584983 - CCS MAPPING WRONG VALUE FROM ITRON ON-DEMAND INTERVAL RESPONSE. VERY LARGE INTERVAL VALUES RESULT |
34600979 | COPY OF BUG 34600978 - COPY OF BUG 34600975 - COPY OF BUG 34581838 - JAVA ERROR OCCURS IN PROD FOR D1-IMD THREADS |
34601019 | COPY OF BUG 34601016 - COPY OF BUG 34601014 - COPY OF BUG 34566053 - MANUAL IMD SCALAR AT VEEREADY STATUS NOT PROCESSED BY D1-IMD BATCH |
34610677 | COPY OF 34610676 - SSN REMOTE DISCONNECT COMPLETES WITH NO EXCEPTION WHEN SSN RETURNS JOB_EXEC_STATUS_FAILURE |
34621961 | COPY OF BUG 34572653 - ILM ARCHIVE SWITCH IS ALWAYS SET TO N WHEN CONVERTING CCB TO MDM/ODM COMPONENTS |
34630770 | COPY OF BUG 34630753 - COPY OF BUG 34630746 - COPY OF BUG 34273256 - SERVICE POINT ONGOING SYNC REQUEST â LEGACY KEY NOT FOUND FOR FIELD |
34645106 | COPY OF BUG 34645103 - COPY OF BUG 34645100 - COPY OF BUG 34641488 - REGRESSION ALL D1-IMD SCALAR THREADS GO TO ERROR |
34662230 | COPY OF BUG 34568030 - ELIGIBILITY CRITERIA USING ALG. TYPE D1-SP-URCF DOESN'T FILTER OUT SP TYPES CORRECTLY |
34671750 | COPY OF BUG 34671746 - COPY OF BUG 34478945 - MANUAL READ CREATION ERROR - VEE EXCEPTION NOT FOUND |
34675052 | COPY OF BUG 34675046 - COPY OF BUG 34675041 - COPY OF BUG 34620952 - UPDATE THE ADD PARTITION STORED PROCEDURE WITH A DEFAULT DOP |
34690166 | ADD A NEW VALIDATION DURING DELETION TO CHECK IF THE ENTITY IS REFERRED BY OTHER ENTITIES |
34695547 | COPY OF BUG 34695541 - COPY OF BUG 34525450 - DEFAULT TIME ZONE NOT PULLED FROM SP WHEN USING SYNC REQUESTS |
34696429 | COPY OF BUG 34696426 - COPY OF BUG 34696424 - COPY OF BUG 34612541 - IN IMD SEARCH SCREEN, IMD TO DO TYPE PAGE GETTING TRANSACTION TIMED OUT ERROR |
34699612 | REMOVE F1-USERNAM WEB SERVICE ANNOTATION |
34702873 | COPY OF 34466838 - COPY OF 33719321 - CUSTOM MDBS IN C2M |
34715249 | COPY OF 34715223 - COPY OF 34714893 - COPY OF 34551776 - SSN PAYLOAD PROCESSING USES WRONG DEMAND DATE TIME (OSB) |
34720344 | COPY OF 34720340 - COPY OF 34416399 - UT SHOWS SYSTEM ERROR WHENEVER IS CREATED |
34731474 | COPY OF 34656300 AFTER 22A WAS DEPLOYED ON 9/17, JOBS CMPSLIDV AND CMPSUIDV HAVE BEEN RUNNING LONGER |
34739136 | COPY OF BUG 34621911 - APPLICANT NAME AND MAIN PHONE FIELD VALUES ARE SET TO BLANK AFTER RECEIVING ANY UPDATE ON ACTIVITY |
34739459 | COPY OF BUG 34576237 - OUTBOUND MESSAGES ARE GETTING CREATED FOR THE UPDATES COMING FROM EXTERNAL SYSTEM THROUGH API CALLS(IWS). |
34739685 | COPY OF BUG 34332888 - OUTBOUND MESSAGES ARE GETTING CREATED WHILE UPDATING SERVICE ORDER FROM EXTERNAL SYSTEM |
34739783 | COPY OF BUG 34474006 - ACTIVITY AND EXTERNAL SYSTEM ISSUE IN THE CCS AFTER INSTALLING THE PATCH 34332888 |
Oracle Utilities Operational Device Management | |
34764351 | COPY OF BUG 32565688 - PURCHASE ORDER REVISION - NO ABILITY TO ADD ADDITIONAL LINE ITEM |
34765336 | COPY OF BUG 34574687 - WHEN ADDING BC LINES TO PR SCREEN SHOWS OVERLAPPING CHARACTERS/FIELDS |
Oracle Utilities Customer Cloud Java Development Environment License Subscription | |
34140718 | ASSET STATUS MOVED FROM "REJECTED" TO "INSTALLED" |
34186356 | OUMDM-25739 PROGRAM CALCULATION RULE |
34246183 | COPY OF 34199753 - BEHAVIOR OF ASSET DISPOSITION AFTER INSTALLATION |
34304043 | DEVICE LOCATION TYPE MAINT PAGE DISPLAYS UNRELATED DEVICE TYPES |
34306462 | COPY OF 33438615 - NAVIGATION ISSUE FOR REGISTRATION POINT PORTAL FOR PREMISE CONTEXT AND SP CONTEXT |
34313581 | FIX ADA COMPLIANCE ISSUES IDENTIFIED IN ADA COMPLIANCE REVIEW BY DEV |
34326891 | USER IS GETTING GENERIC ERROR IN RESPONSE WHEN SERVICE HISTORY TYPE IS NOT ADDED FOR "X1-DACSEVTACT" IWS TESTING |
34328685 | COPY OF BUG 34328664 - FORTIFY NULL DEREFERENCE ISSUE IN OUTBOUNDMESSAGETYPEDIFFERSBYSERVICETASKTYPEALGCOMP_IMPL |
34337912 | COPY OF 34337897 COPY OF 34311719 - X1-MIGP BATCH ISSUE WITH GROOVY X1PROCPIDS |
34341638 | MODEL IN CONTROLLABLE DEVICE SPECIFICATION SHOULD BE A DROPDOWN |
34343413 | ADA CROSS INSTALLED METER: THE SEQUENCE NUMBER FOR BUTTONS NEEDS TO BE IN LOGICAL ORDER IN THE FLOW OF THE PAGE |
34379225 | COPY OF BUG 34298744 - X1-MIGSP DM BATCH CANNOT CREATE MDM SP DUE TO INPUT REQUEST FIELD DEVICE LOCATION HAS INVALID VALUE |
34385971 | OUMDM-25628 PROGRAM SUBSCRIPTION (C2M) - PART 2 |
34386041 | OUMDM-25739 PROGRAM CALCULATION RULE (BO+UI) - PART 2 |
34386851 | OUMDM-25737 DEVICE LOCATION |
34386861 | OUMDM-25740 CONTROLLABLE DEVICE |
34404499 | CROSS INSTALLED METER: ADDITIONAL CUSTOMER CONTACTS INFORMATION ADDED TO THE REPORT WHENEVER USER CLICKING AT PREVIOUS AND THEN NEXT |
34413351 | CROSS INSTALLED METER: THE APPLICATION NOT DISPLAY FOR CROSSED INSTALLED METER WHEN USING THE WORD "PROCESS" AND "CROSS" IN SEARCH MENU |
34436174 | OUMDM-27385 MIGRATE INTERVAL PROFILE DATA SET - MASTER CONFIGURATION CHANGES |
34458770 | COPY OF 34220101 - UPDATE BILL SEGMENT MDM PERIOD (X1-UPBS) |
34472699 | COPY OF BUG 33956168 - COPY OF BUG 33923130 - SERVIE HISTORY ON ASSET IS SENT IN THE OUTBOUND , WHEN 'TRACKED BY ODM' IS NOT MARKED ON THE DEVICE TYPE |
34474011 | OUMDM-27386 MIGRATE INTERVAL PROFILE DATA SET - MIGRATE ADMIN CHANGES |
34475071 | CROSS INSTALLED METER: MISSING MESSAGE "SWAP METERS SUCCESSFULLY PERFORMED" ONCE METERS COMPLETED SWAPPING. |
34485768 | UGBUPD-11873 SUBSCRIPTION CHARACTERISTICS |
34491654 | OUMDM-27387 MIGRATE INTERVAL PROFILE DATA SET - MIGRATE INTERVAL PROFILE |
34493435 | COPY OF 34493433 - COPY OF 34466030 - USAGE PERIOD END DATE/TIME IS ALWAYS BEING SET TO MIDNIGHT |
34494924 | COPY OF BUG 34397333 - INSTALLATION EVENT FOR ON SCENARIO NOT CREATED AFTER X1-MIGSM JOB DUE TO W1-PREQPTMNT / SYNC REQUEST |
34502208 | CROSS INSTALLED METERS - ADJUSTMENTS ARE NOT BEING CREATED CORRECTLY |
34506136 | COPY OF 34452964 - SERVICE POINT SOURCE STATUS "CONNECTED" IS INVALID ON START SERVICE REQUEST |
34527411 | COPY OF BUG 34384316 - X1MISTOCKLOC (X1-MIGAD) FROM STOCK LOCATION IS NOT POPULATING PARENT NODE OF OOSL/STORAGE LOCATION |
34534907 | OUMDM-23383 - PROGRAM TRANSACTION (PART 2) |
34534955 | OUMDM-27388 MIGRATE INTERVAL PROFILE DATA SET - MIGRATE INTERVAL PROFILE DATA SET |
34536852 | COPY OF 34482052 - X1-UPBS DOES NOT SET MDM PERIOD TO EARLIEST BSEG READ START DTTM & LATEST BSEG READ END DTTM |
34545515 | COPY OF 34545497 - COPY OF 34543453 - X1-MIGSA MIGRATE SA ISSUE IN SETTING MDM SP ID |
34553496 | OUMDM-27389 MIGRATE INTERVAL PROFILE DATA SET - MIGRATE SA CHANGES |
34556889 | CONTROLLABLE DEVICE FOLLOW-UP ITEMS |
34558309 | COPY OF BUG 34557941 - NULLPOINTEREXCEPTION IN X1MIGPERFLAG (X1-MIGAD) - CANNOT POPULATE CONTACT TYPE TABLE WITH THAT FROM PERSON BUSINESS FLAG TABLE |
34561225 | CROSS INSTALLED METER: CUSTOMER CONTACT CREATING LINKED TO THE PREMISE ONLY WON'T SHOW UP ON THE CUSTOMER 360 PORTAL IN THE CUSTOMER ACTIVITY HISTORY ZONE |
34575438 | OUMDM-27985 MIGRATION - ADDITIONAL CHANGES |
34577514 | COPY OF 34577506 - COPY OF 34511968 - USAGE REQUESTâUSAGE PERIODS ARE MISSING STANDARD PERIODS |
34583489 | DEVICE LOCATION FOLLOW-UP ITEMS |
34607337 | OUMDM-25739 PROGRAM CALCULATION RULE (DERIVE QUANTITY ALGORITHMS AND COMMON ROUTINES) |
34608196 | COPY OF 34550082 - CMA : PERFORMANCE ISSUE ON C1-ACCOUNT MIGRATION PLAN |
34618290 | COPY OF BUG 34459084 - X1-MIGSP IS NOT POPULATING MDM-SP & ODM-NODE'S CREATION DATE BASED ON CI_SP'S INSTALL DATE |
34624019 | DACS: IWS - DEVICE RESERVATION |
34635227 | OUMDM-28419 PROGRAM SUBSCRIPTION (C2M) - PART 3 (CHANGES+FR) |
34639889 | DACS DEVICE LOCATION TYPE POTRAL AND REGULAR SERVICE POINT TYPE SHOULD BE FIXED. |
34644830 | DACS: BATCH CONTROL: CANCEL PROGRAM EVENT DEVICE RESERVATION |
34648789 | UGBUPD-11224 - EVENT PARTICIPATION ERROR BO |
34653339 | COPY OF 34605197 - IN 2.8, BILL SEGMENT IS DELETED WHEN AN SP IS NOT SCHEDULED FOR READING AS OF CUT-OFF UNLIKE 2.7. |
34664061 | COPY OF 34664036 : USAGE FORECAST (CX ALGORITHM) IS NOT SHOWING THE INSIGHT CARD |
34669914 | COPY OF BUG 34641136 - X1-MIGMR PREVIOUS MEASUREMENT DTTM NOT POPULATED ON FMD, LATEST MEASUREMENT DTTM NOT POPULATED ON MC |
34676566 | DACS: POST-EVENT OUTCOME |
34676573 | DACS: BO ENTER: SUBMIT CANCEL PROGRAM EVENT DEVICE RESERVATION JOB |
34676587 | DACS: BO ENTER: COMPLETE PROGRAM EVENT |
34696254 | DACS: IWS: CANCEL PROGRAM EVENT DEVICE RESERVATION |
34706648 | UGBUPD-11225 METERED SERVICE TYPE, METERED SERVICE, METERED SP & METERED SP TYPE |
34716620 | MIGRATE SA: ADD ERROR WHEN INTERVAL PROFILE TYPE MAPPING IS NOT FOUND |
34720786 | DEVICE LOCATION AND PROGRAM LIVE AND END AT THE SAME TIME AS PROGRAM SUBSCRIPTION |
34732080 | DACS: IWS - POST-EVENT OUTCOME SCRIPT REFACTORING |
34738648 | [DACS] REFACTOR: DEVICE RESERVATION |
