Requirements by Tier
The application is deployed on multiple Tiers:
• Tier 1, Desktop
• Tier 2, Web/Business Application Server
• Tier 3, Database Server
Tier 1, Desktop: Software and Hardware Requirements
Minimum monitor display size: 1920 X 1080
Tier 2, Web/Business Application Server: Software and Hardware Requirements
Refer to
Supported Platforms to determine which web application servers can be used with the operating system that will be hosting this tier.
The recommendations that follow are based on a standard installation with both the web application and business application servers on the same machine and the system running with the default values. The default values may not support a production environment. You should adjust these values according to your production needs. Refer to the Server Administration Guide on how to change the default values. The minimum resource requirements exclude third-party software installation requirements. Refer to the third- party vendors for specific requirements. The following sizing excludes the Oracle database server installation.
Tier 3, Database Server: Software and Hardware Requirements
Refer to
Supported Platforms for information about the supported database servers.
