Supported Integrations
The following integrations are supported in this version of Oracle Utilities Digital Asset Management.
• Oracle Utilities Digital Asset Management 2.0.0.0.0 Integration to Oracle Utilities Distributed Energy Resources Management System
Note: Version numbers listed below are supported as of the v2.0.0.0.0. release (January 2023). Refer to the Certification Matrix for Oracle Utilities Products (Document ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products have been added.
