Password Management
Oracle Utilities Digital Asset Management uses several passwords, which require to be changed on a regular basis to conform with security best practices:
Password Owner
Location
Comments
Online User
Domain Authentication Source
No configuration changes. User changes password in security repository directly or indirectly using security products. Security repository is configured in Oracle WebLogic.
WEB_SPLPASS specifies the default password for the initial user. If this user is used past the installation the password may need to be changed. Refer to the Server Administration Guide for more details.
Web Service User
Batch User
Operating System
Database Users
BATCH_DBPASS
DBPASS
XAI_DBPASS
The database users are stored in ENVIRON.INI. Refer to the Server Administration Guide on process to change values. New Passwords need to be re-encrypted.
JMX Users
BSN_JMX_SYSPASS
The default JMX user is stored in ENVIRON.INI. Refer to the Server Administration Guide on process to change values. New Passwords need to be re-encrypted.
Administration Account
WLS_WEB_WLSYSPASS
WEB_WLSYSPASS
The default administration users are stored in ENVIRON.INI. Refer to the Server Administration Guide on process to change values. New Passwords need to be re-encrypted.
