Variable | Usage |
ANT_ADDITIONAL_OPT | Options for ant in accordance with the configuration settings at installation time. |
ANT_HOME | Location of ant build utilities. |
ANT_OPTS | Options for ant for Oracle SDK. |
ANT_OPT_MAX | Maximum memory settings for ant in accordance with the configuration settings at installation time. |
ANT_OPT_MIN | Minimum memory settings for ant in accordance with the configuration settings at installation time. |
CMPDB | Database Type (ORACLE). |
DBNAME | Database Name. |
ENVFILE | Location and name of environment configuration file. |
HIBERNATE_JAR_DIR | Location of Hibernate Java library. |
HOSTNAME | Name of host (fully qualified). |
JAVA_HOME | Location of JDK. |
LD_LIBRARY_PATH | Library Path. |
NLS_DATE_FORMAT | Oracle NLS Date Format. |
NLS_LANG | Oracle NLS Language string. |
NLS_SORT | Oracle NLS Sorting. |
ONLINEBILLINI | Location of document rendering software template building configuration files. |
ONLINEDOCINI | Location of document rendering software configuration files. |
OPSYS | Operating System Name. |
OPSYSINFO/OPSYSVER | Operating System Version. |
ORACLE_CLIENT_HOME | Location of the Oracle Client software (used for location of perl). If full Oracle Database software is installed on the host this value will match ORACLE_HOME. |
ORACLE_HOME | Location of the DBMS software. |
OSTYPE | Operating System Type. |
PERL5LIB/PERLIB | Location of Perl Libraries. |
PERL_HOME | Location of Perl. |
SERVER_ROLES | Roles enable for this server. |
SERVER_ROLE_BATCH | Whether the batch server is included. |
SERVER_ROLE_INTEGRATION | Whether the integration server is included. |
SERVER_ROLE_ONLINE | Whether the online server is included. |
SPLADMIN | Administration user ID. |
SPLADMINGROUP | Administration group. |
SPLApp | Name of root web application WAR file. |
SPLAPP | See SPLOUTPUT. |
SPLBCKLOGDIR | Location of backups of online log files (must be set manually). |
SPLEBASE | Location of software for environment. |
SPLENVIRON | Name of environment. |
SPLOUTPUT | Location of output for environment. |
SPLRUN | Location of runtime for environment. |
SPLSDKROOT | Location of SDK (Development environment only). |
SPLSYSTEMLOGS | Location of product specific logs. |
SPLVERSION | Version identifier of product (prefixed with V). |
SPLVERSION_NUM | Version number of product. |
WEB_ISEXPANDED | Whether web application is expanded or not (not = WAR/EAR files). |
WEB_SERVER_HOME | Location of web application server software. |
WL_HOME | Location of Oracle WebLogic installation (WebLogic supported platforms only). |
