System Encryption
The system automatically encrypts certain fields captured in various option tables or context tables. This is mainly used for passwords. For example, passwords captured in Message Sender context or password
In addition, batch control supports configuring a security option for parameters that capture sensitive information, such as a password. Refer to
Defining Batch Controls for more information.
It is also possible to enable system encryption using the characteristic type
F1-PWD. However, the maintenance object must include specific code to enable system encryption for characteristics of this type. In Oracle Utilities Application Framework, the only maintenance object that supports this is extendable lookup. Refer to
Extendable Lookup Advanced Topics for more information.
Parent topic
