Defining Insight Groups
The insight group entity allows implementations to define multiple related insight types that should be displayed together in a given user interface map or zone. Refer to
Insight Groups for an overview of insight group configuration and functionality.
To view or maintain insight groups, open > >
This is a standard
All-in-One portal.
The information captured on the insight group depends on the record's business object. Refer to the embedded help text for more information.
Related Insight Types
The Related Insight Types zone displays all the insight types that are currently linked to the group. The Edit link in the zone header allows you to add or remove insight types. Only insight types that reference one of the Valid Visual Structures may be selected.
Parent topic
