About Bundling
Bundling is the process of grouping entities for export or import from one environment to another.
For example, you might export a set of business objects and service scripts from a development environment and import them into a QA environment for testing. The group of entities is referred to as a bundle. You create export bundles in the source environment; you create import bundles in the target environment.
Working with bundles involves the following tasks:
• Configuring entities for bundling if they are not preconfigured
• Creating an export bundle, which contains a list of entities to be exported from the source environment
• Creating an import bundle to import those entities to the target environment
• Applying the import bundle, which adds or updates the bundled entities to the target environment
Parent topic
