Understanding Cube Viewer
The framework provides a cube viewer portal which is intended to be used for most implementations of cube views. It supports a number of common actions and data representations.
The choice of appropriate menu for the Cube Viewer portal will differ from product to product. Refer to your product specific documentation for more information on how to access the viewer.
The following sections describe the basic concepts and features of the cube viewer.
Parent topic
