Defining Analytics Options
Refer to
Understanding Operational Analytics for an overview of the operational analytics functionality.
Your specific product may require some system wide configuration to be defined when using operational analytics.
Navigate to the
Extendable Lookup portal. Search for and select the
Analytics Options business object.
Use the embedded help to review information about the options to define.
Parent topic
