Accessibility Considerations
This section provides information about topics related to accessibility that should be considered when extending the system via configuration tools.
Color Contrast
The HTML color red (RGB code #FF0000) when used for text on a white background does not comply with the accessibility color contrast guidelines. When it is desired to use red for text for emphasis in a zone, map or in a text string, the product recommends the shade of red with the RGB code #E0292F.
Note that in addition, the product provides a special CSS class textColorRedOnWhite which may be used when HTML references are used for applying the red color. For example, UI map, zone help text and scripting.
Parent topic
