Business Object - Main
Use this page to define basic information about a business object. Open this page using > >
Use the Business Object Query portal to search for an existing business object. Once a business object is selected, you are brought to the maintenance portal to view and maintain the selected record.
Description of Page
Enter a unique Business Object name and Description. Use the Detailed Description to describe the purpose of this business object in detail. Owner indicates if this business object is owned by the base package or by your implementation (Customer Modification).
CAUTION:
Important! If you introduce a new business object, carefully consider its naming convention. Refer to
System Data Naming Convention for more information.
Enter the Maintenance Object that is used to maintain objects of this type.
Enter a
Parent Business Object from which to
inherit business rules.
Lifecycle Business Object is only displayed for child business objects, i.e. those that reference a parent business object. It displays the highest-level business object in the inheritance hierarchy. Refer to
Inheriting Lifecycle for more information.
Application Service is the application service that is used to provide security for the business object. Refer to
Granting Access To Business Objects for more information. The application service on the child business object must have the same valid actions as the application service on the parent business object.
Use
Instance Control to allow or prevent new entities from referencing the business object. Typically only the
identifying BOs are marked to allow new instances.
Click the
View Schema hyperlink to view the business object's expanded schema definition. Doing this opens the
schema viewer window.
Click the View XSD hyperlink to view the business object's expanded schema definition in XSD format.
The options grid allows you to configure the business object to support extensible options. Select the Option Type drop-down to define its Value. Detailed Description may display additional information on the option type. Set the Sequence to 1 unless the option can have more than one value. Owner indicates if this option is owned by the base package or by your implementation (Customer Modification).
Note:You can add new options types. Your implementation may want to add additional option types. For example, your implementation may have plug-in driven logic that would benefit from a new option. To do that, add your new values to the customizable lookup field
BUS_OBJ_OPT_FLG. If you add a new option type for a business option, you must update its maintenance object to declare this new option type. Otherwise, it won't appear on the option type dropdown. You do that by referencing the new option type as a
Valid BO Option Type maintenance object option.
Parent topic
