Monitor Rules
You can define algorithms to monitor a business entity while it is in a given state. This type of logic is typically used to check if the conditions necessary to
transition the entity to another state exist (and, if so, transition it). For example, transition an entity to the
Canceled state if it's been in the
Error state too long. Another common use is to perform ancillary work while an entity is in a given state. For example, update statistics held on the object while it's in the
Active state.
Monitor algorithms are invoked when a business entity first enters a state and periodically after that in
batch. You have the option to defer the monitoring of a specific state until a specific monitoring batch job runs. You do so by associating the state with a specific monitoring process. In this case the system will only execute the monitoring rules of this state when that specific batch process runs. This is useful when processing one type of record typically creates another type of record. You may want the processing of the second set of records to be deferred to a later time.
A monitor algorithm can carry out any business logic. In addition it can optionally tell the system to do either of the following:
• Stop monitoring and transition to another state. The system will not call any further monitoring algorithm plugged in on the state and attempt to transition the entity to the requested new state.
• Stop monitoring. Same as above except that no transition takes place. You may want to use this option to prevent transitions while some condition is true.
If none of the above is requested the system keeps executing subsequent monitoring algorithms.
Also note that when a record is processed by the monitor batch program, by default the BO Post Processing, BO Audit and MO Audit algorithms are not executed. However, it is possible for a monitor algorithm to indicate that the other algorithms should be executed by the batch process by setting the “force post processing” indicator to true.
Parent topic
