Changes to ENVIRON.INI
This section is optional and is only applicable for on-premise customers.
This section focuses on the parameter configurations in the ENVIRON.INI file:
OWSM_PROTECTION_FOR_REST_SERVICES
This parameter should be configured only if Oracle Web Service Manager Protection has to be enabled for REST services.
The default parameter value is set to ‘true’ in the ENVIRON.INI file. Set it to ‘false’ if Oracle Web Service Manager is not configured. Also the WEBSERVICES_ENABLED parameter value should be set to ‘true’.
The ENVIRON.INI file is found in the etc folder of the environment (example: / scratch/<environment name>/etc).
Field | Value |
OWSM_PROTECTION_FOR_REST_SERVICES | false |
WEBSERVICES_ENABLED | true |
Important! These parameters should be configured properly to launch the GIS Viewer.
CLOUD_RESTRICTION_URLS_ENABLE
Configure this parameter only if a set of server URLs should be accessed from the Oracle Utilities Work and Asset Management system.
The default parameter value for this parameter is set to ‘false’. If the parameter value is set to ‘true’, the GIS server URLs that are configured in ESRI Maps Master Configuration and ESRI WAM Integration Master Configuration objects should be mentioned in the whitelist xml file configured in the CLOUD_WHITE_LIST_PATH parameter’.
Parent topic
