Configuring Property Files
The property or Config file is located where the jar file exists. Copy the Config file to the location of the jar file. Refer to the
Deploying the Jar File section for information about the folder.
Configuring the property file is a one-time step by the Administrator to set up the synchronization process. The property file consists of input parameters required for the GIS Extractor program to establish a connection to the Geodatabase.
The parameters to be configured in the property file are:
• keyDBServer — Database server name
◦ Example: xxxxxxxxxxxxx.us.oracle.com
• keyDBInstance — Database instance name
◦ Example: sde:oracle11g:WAMV2200DEV
• keyDBName - Database name
◦ Example: WAMV2200DEV
• keyDBUser - Database user name
◦ Example: sde
• keyDBPwd — Database user password
• keyUsername - ArcGIS Server user name to generate security token
◦ Example: siteadmin
• keyPassword - ArcGIS Server user password
◦ siteadmin
• keyExpiration - Token Expiration duration in seconds
◦ Example: 60
Parent topic
