Defining Customer Questions
You use the Question portal to display and maintain customer questions.
You can access the portal by selecting Admin, General, Customer Question. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Question: This zone displays the selected question.
Parent topic
